Joined: 2/1/2018(UTC) Posts: 9  Location: Germany Thanks: 11 times Was thanked: 2 time(s) in 2 post(s)
Hi, we set up a Midi-Controller to control our Instant Replay. Everything works fine, except the ReplayChangeSpeed, when the Fader on the Midi-Controller gets moved, ReplaySpeed jumps to 10%. The values, the Midi-Controller supplies correct values. We checked that already.
Any Idea or a Bug? The same Fader works perfekt for the SetFader Shortcut.
Thanks!
Joined: 8/3/2015(UTC) Posts: 323 Location: Chicago, IL
What Midi controller are you using?
Thanks: 10 times Was thanked: 33 time(s) in 28 post(s)
There was a discussion about assigning midi faders to replay speed in this thread: https://forums.vmix.com/....aspx?g=posts&t=5757Perheps it directs to a working solution. I've decided to use different buttons with fixed values to set replay speed.
