rowby
#1 Posted : Wednesday, January 31, 2018 1:35:32 PM(UTC)
rowby
Hello Everyone,
Can I add stingers to a Playlist??
I'm trying to add stingers between each item -- using triggers, but am not seeing them incorporated. (BTW, I'm using manual mode, and the stingers have alpha channels.)
Maybe stringers are not possible in playlists?
Thanks!
Rowby
Cpilcher
#2 Posted : Wednesday, January 31, 2018 2:00:17 PM(UTC)
Cpilcher
I'm not near my vMix PC but maybe you could create a solution using 2 list inputs. you could transition between them with a stinger. Not an ideal solution...
gandfproductionsinc
#3 Posted : Friday, March 2, 2018 1:19:37 AM(UTC)
gandfproductionsinc
I spent some time and I think it could be done using triggers, however, I don't think it would work in the playlist which would be a great addition.
gandfproductionsinc
#4 Posted : Friday, March 2, 2018 12:25:52 PM(UTC)
gandfproductionsinc
I now have the answer:
Go to your playlist item and double-click it, then look for the transition and change from cut to the stinger you want.
Cpilcher
#5 Posted : Friday, March 2, 2018 12:34:14 PM(UTC)
Cpilcher
Thanks for the update. A simple solution as always, this gives me a few ideas as well.
rowby
#6 Posted : Friday, March 2, 2018 12:42:35 PM(UTC)
rowby
Thanks, I’ll try that out. Rowby
Barney Box Lane
#7 Posted : Sunday, March 4, 2018 10:44:48 AM(UTC)
Barney Box Lane
you can trigger stingers to each input used in the play list for different ones, as long as you're happy with them still transitioning the same outside of 'playlist mode'
rowby
#8 Posted : Sunday, March 4, 2018 11:06:43 AM(UTC)
rowby
Or possibly you could create a virtual input and use that for the playlist.....??? Then the stinger would only be on the playlist version of that input It would not touch the master versin of the input....correct????? (I’m just guessing.
Barney Box Lane
#9 Posted : Monday, March 5, 2018 8:29:02 AM(UTC)
Barney Box Lane
off the top of my head, yeah but I'm pretty sure there's something like you can't create a virtual input of a video or list input.
if you can do it per input you'll have more flexibility, for instance using stinger 2 (I like automation but not repitition)
rowby
#10 Posted : Monday, March 12, 2018 4:53:23 PM(UTC)
rowby
Hello Everyone,
For those following this thread, you can change your transitions in a playlist. As indicated in this thread, you just open your playlist, and click on the specific input you want to change the transition to.
While I wish there were more Stingers available by default then just 2, at least we have a slew of transitions we can use.
See attached screen capture, it pretty much shows how it's done.
Rowby
rowby attached the following image(s):
