Thanks: 8 times Was thanked: 7 time(s) in 5 post(s)
Hi Everyone,
Trying to get live stats for titles working for our first vMix production. First I thought it was an XML issue so I tried other XML example files and they worked fine. The URL links to an XML file, however when I check the source it is all HTML and CSS. I have limited experience with XML and can't get vMix to accept it as a data source. The league is using PrestoSports for their websites and stats. When I view the website I can see the live stats being update and it doesn't require a login to see. Would this work directly with vMix, or would I need a scorebot type device as well.
Did you have any luck with using PrestoSports data?
I'm considering moving to vMix but would like to pull stats data from prestosports as well.
Unfortunately we did not have time to coordinate with the teams to get access to xml files so we didn't try. It would be a great relief for us to have the data automated. If we continue to use vMix it will be a priority for sure.
