Argo82
#1 Posted : Monday, January 22, 2018 9:27:45 AM(UTC)
Argo82
Was thanked: 7 time(s) in 5 post(s)
Hi Everyone,
Trying to get live stats for titles working for our first vMix production. First I thought it was an XML issue so I tried other XML example files and they worked fine. The URL links to an XML file, however when I check the source it is all HTML and CSS. I have limited experience with XML and can't get vMix to accept it as a data source. The league is using PrestoSports for their websites and stats. When I view the website I can see the live stats being update and it doesn't require a login to see. Would this work directly with vMix, or would I need a scorebot type device as well.
mdbcs
#2 Posted : Saturday, January 27, 2018 3:51:07 PM(UTC)
mdbcs
Did you have any luck with using PrestoSports data?
I'm considering moving to vMix but would like to pull stats data from prestosports as well.
Argo82
#3 Posted : Wednesday, January 31, 2018 5:41:18 PM(UTC)
Argo82
Unfortunately we did not have time to coordinate with the teams to get access to xml files so we didn't try. It would be a great relief for us to have the data automated. If we continue to use vMix it will be a priority for sure.
