jvphobic
#1 Posted : Thursday, January 25, 2018 6:50:30 PM(UTC)
jvphobic
Was thanked: 11 time(s) in 10 post(s)
Maybe I am missing something easy. How do I have the Instant replay shot NOT use the replay audio and instead a different live audio like a Vmix Call or onboard audio? Everytime I switch to the replay, it takes off all the other audio options. I would think there is something in the triggers to make it turn on another audio source, but for the life of me I can't find it or get it to work.
TL;DR...
I want replay shots to have live audio, not replayed audio.
#2 Posted : Thursday, January 25, 2018 8:05:46 PM(UTC)
@ jvphobic
This can easily be accomplished by setting your main LIVE audio source to be "Always ON" (disable its double arrow icon and enable its speaker icon in the audio mixer).
Similarly, you need to (or at least should) lower the Replay A audio level to 0 or barely audible.
You may need to set-up "Triggers" to turn the main LIVE audio source ON and OFF for those times and situations when you don't want it LIVE (like during a commercial break for example).
jvphobic
#3 Posted : Friday, January 26, 2018 10:33:36 AM(UTC)
jvphobic
Ugggggh. That is kinda cruddy. Because I have about 5 "live" shots and about 30 commercials. So creating triggers for 30 different shots really seems backwards. I think I need to make a feature request...
#4 Posted : Friday, January 26, 2018 2:06:56 PM(UTC)
@ jvphobic
As with vMix, there is always more than one way to do things, the key is using one that works best in your workflow.
The other option, and probably better for your situation, is to ADD your LIVE Audio Sources as MultiView Overlays of the Replay A Input and disable the video component if existent on the Audio Source (tic box next to Overlay #).
Provided your Audio Sources are set to Audio follows Video (enabled double arrow icon), you should be good to go.
The third option is to set-up "Triggers" on the Instant Replay Input to turn your Audio Sources ON and/or OFF.
jvphobic
#5 Posted : Friday, January 26, 2018 6:52:14 PM(UTC)
jvphobic
I tried the trigger option on the instant replay A shot. It didn't seem to work. I didn't realize that clicking the checkbox on the Multiview just removed the video. I thought it disabled the overlay completely. I will look at that for sure. That would be the VERY easy solution then.
jvphobic
#6 Posted : Friday, January 26, 2018 9:22:58 PM(UTC)
jvphobic
Solved. This worked out great. Thanks IceStream. All this time I thought that removing the checkbox disabled the input, not just got rid of the video. My setup looks like it will work fantastic now.
Similar Topics
Instant replay audio only on firts part (Instant Replay)
by Laky 3/18/2021 11:05:53 PM(UTC)
Instant Replay Audio selection (Feature Requests)
by xaver 2/25/2020 11:45:10 PM(UTC)
Instant Replay Audio Source (Feature Requests)
by xaver 9/30/2019 8:52:15 PM(UTC)
Instant Replay Audio request (Feature Requests)
by jvphobic 1/26/2018 10:41:41 AM(UTC)
Instant Replay Audio Choice (Instant Replay)
by jvphobic 8/4/2017 2:02:16 PM(UTC)
Probably bug in instant replay audio strip configuration? (Instant Replay)
by pm 11/8/2016 5:33:06 AM(UTC)
Instant Replay Audio Channels (Feature Requests)
by Kibim 6/18/2015 5:01:09 AM(UTC)
