brian078
#1 Posted : Thursday, January 25, 2018 1:49:41 PM(UTC)
brian078
My idea is to group audio sources.
It would be very useful if users could assign audio sources to a group.
Then you could control the combined volume of several sources at once.
This also allows users to apply effects on a group, for example a limiter on the total of 2 commentators.
To illustrate the idea, I created this example.
thanks 1 user thanked brian078 for this useful post.
ThomasM on 1/25/2018(UTC)
rowby
#2 Posted : Thursday, January 25, 2018 1:50:39 PM(UTC)
rowby
+1
ThomasM
#3 Posted : Thursday, January 25, 2018 4:34:59 PM(UTC)
ThomasM
Netherlands
+1
Peter B
#4 Posted : Thursday, January 25, 2018 6:25:25 PM(UTC)
Peter B
Being able to send the AB buses to the Master would be very useful.
https://forums.vmix.com/...aspx?g=posts&t=12268
zenvideo
#5 Posted : Sunday, January 28, 2018 4:03:00 PM(UTC)
zenvideo
Views messages in topic : 521
The creation of Sub-mix groups would be useful, and complement the existing A-B Aux outputs. Presumably the difference being that the A/B/Headphones outputs are in an "AND" configuration (where you can potentially send to A and B and Master), whereas these sub-mix groups would be in an "OR" configuration where an input channel would be sent to either the Master or sub-mix-1 or sub-mix-2, etc, and all sub-mixes would feed into the Master (as well as having the same A/B/Solo controls options as normal input channels).
stevespaw
#6 Posted : Sunday, January 28, 2018 5:35:36 PM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
You can send A and B to the Master.
We do this all the time and at least have 2 channels of submix.
Steve
Peter B
#7 Posted : Monday, January 29, 2018 2:37:51 PM(UTC)
Peter B
Steve
How are you doing this ?
