Joined: 12/3/2013(UTC) Posts: 17  Location: Netherlands Was thanked: 2 time(s) in 2 post(s)
My idea is to group audio sources. It would be very useful if users could assign audio sources to a group. Then you could control the combined volume of several sources at once. This also allows users to apply effects on a group, for example a limiter on the total of 2 commentators. To illustrate the idea, I created this example.
 1 user thanked brian078 for this useful post.
Joined: 11/23/2016(UTC) Posts: 330  Location: USA Thanks: 179 times Was thanked: 26 time(s) in 25 post(s)
Joined: 1/25/2018(UTC) Posts: 15   Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
The creation of Sub-mix groups would be useful, and complement the existing A-B Aux outputs. Presumably the difference being that the A/B/Headphones outputs are in an "AND" configuration (where you can potentially send to A and B and Master), whereas these sub-mix groups would be in an "OR" configuration where an input channel would be sent to either the Master or sub-mix-1 or sub-mix-2, etc, and all sub-mixes would feed into the Master (as well as having the same A/B/Solo controls options as normal input channels).
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 153 times Was thanked: 76 time(s) in 57 post(s)
You can send A and B to the Master. We do this all the time and at least have 2 channels of submix. Steve
Steve
How are you doing this ?
