Feature Requests
Better chroma keying = adjustable Choke & Soften
Joined: 11/14/2012(UTC) Posts: 353  Location: Finland Thanks: 217 times Was thanked: 23 time(s) in 21 post(s)
Joined: 1/13/2010(UTC) Views messages in topic : 5,317  Location: Gold Coast, Australia Was thanked: 4719 time(s) in 1617 post(s)
These options already exist in the combined "Chroma Key Filter" option. Try moving the Chroma Key slider all the way to the right and slowly adjust the Chroma Key Filter until you have the required amount of background removal and edge blur.
Martin vMix
Hi Martin! Yes, I have played around a lot with the Keyer and it is quite good as real time chroma keyer, but I still would have to have more control over the edge feathering. This feathering should be done lastly, after the Keyer setup. This could maybe be done with the existing anti aliasing -function, but it should have adjustable control how much anti aliasing is applied. It would also be nice if vMix could use some kind of buffering so that information from multiple (previous) frames would be used to get more stable key (less jitter). Kind rerards, J. Tervo
Video mixed with vMix (studio portions). Turn subtitles / CC on:
Joined: 11/21/2017(UTC) Posts: 124  Location: Philadephia, PA Thanks: 31 times Was thanked: 14 time(s) in 9 post(s)
Feature Requests
