Philipp
#1 Posted : Thursday, January 25, 2018 12:25:11 PM(UTC)
Philipp
As i am using this Program as a Mediaplayer for live stage production i am missing one major Function, it would make live so much easier if you could just output the timecode of a played back audio or video file.
Peter B
#2 Posted: : Thursday, January 25, 2018 6:34:41 PM(UTC)
Peter B
+1
A workaround could be having a timecode audio file as a separate audio
source and roll this in sync with your file using a trigger.
krassesPferd
#3 Posted : Wednesday, October 17, 2018 6:27:27 PM(UTC)
krassesPferd
Was thanked: 8 time(s) in 7 post(s)
+1
Some applications only allow MIDI TC in. So it would be possible to synchronise your GRANDMA2 on PC lighting console with vMix videos
Best regards
Yannick
BETech
#4 Posted : Thursday, October 18, 2018 12:04:52 AM(UTC)
BETech
Timecode in vMix Video clips can be achieved using a video editing application that can export audio in the 5.0 specification. The QuickTime codec for export in both OSX and Windows can accomplish this task. The settings below will get you started. In this scenario, I have tracks 1 & 2 with a stereo music clip, track 3 has pre-recorded voice cues and track 4 timecode starting at 00:00:00:00.
Tip: You can download customized timecode *.wav files generated by a web application online, with your specific needs in mind. Frame rate, Timecode start time, duration and sampling rate:
http://elteesee.pehrhovey.net/
Tip: Make sure your editing software is set-up to output four output channels, and map those timeline audio tracks 1-4 accordingly. Most editing systems default to stereo, two channel output and export.
Import the rendered exported video clip back into the editing system to verify that you indeed have the five audio tracks, and the audio tracks are correctly assigned in the order with the original soundtracks you desired.
The next step is to create a new Input and add the video clip to vMix. Open the Audio settings for the video clip and select Channel Mixer. Upon playing the video clip, you should see all the audio tracks compiled from the edit session. In this image, I have four audio tracks.
Now we set-up the Channel Matrix. This will send the audio tracks to their destination hardware or NDI output.
In this example, audio tracks 1 & 2 are sent to the Master output and the Headphones. Track 3 (audio cues) and track 4 (timecode) are sent to Bus A (left & right).
Now Bus A with the pre-recorded voice cues (3) and timecode (4) can be sent to several destinations depending on your hardware set-up. Possibilities: External 2 with a SDI de-embedder to extract the audio channels; a secondary sound card (internal or low latency USB audio device), via NDI to a destination workstation or laptop to extract the audio tracks, or even a Timecode to Midi Timecode converter. To many choices to cover in this tutorial.
Below: an example using a secondary sound card in the host computer.
Further, there are software applications that can convert Timecode to Midi Timecode should this be a requirement.
https://www.videotoolshe...tc-midi-readerconverter/
You can download the 5.0 Audio Test Video Clip for your tests:
https://drive.google.com...2wTDUx2/view?usp=sharing
https://www.youtube.com/user/editec2010
Hope this helps in some way, though there probably other ways to achieve your goal. Cheers.
thanks 2 users thanked BETech for this useful post.
stevespaw on 10/19/2018(UTC), Philipp on 12/23/2019(UTC)
