mscorlib error with flash swf
Thanks: 8 times Was thanked: 46 time(s) in 23 post(s)
Hello, Martin,
I tried to use a flash in vMix ang got an error saying: "Value cannot be null. parameter name: pUnk. mscorlib AddnewInput". I also installed the latest flash player. I checked that NET framework 3.5 SP1 is installed + Windows 7 64bit.
Any ideas, what is the problem?
Joined: 1/13/2010(UTC) Posts: 5,316  Location: Gold Coast, Australia Was thanked: 4718 time(s) in 1616 post(s)
Looks like the flash installation is corrupt somehow. I have tested vMix 2011 Beta 3 on Windows 7 x64 using the latest Flash Player for Internet Explorer (10,2,153,1) (you can test your flash version here: http://www.adobe.com/software/flash/about/ (use internet explorer if you usually use another browser))
Thanks, problem solved. I had flash installed, but not the IE version. Actually IE was removed :)
