dundurs
#1 Posted : Thursday, April 7, 2011 3:44:22 PM(UTC)
dundurs
Was thanked: 46 time(s) in 23 post(s)
Hello, Martin,
I tried to use a flash in vMix ang got an error saying: "Value cannot be null. parameter name: pUnk. mscorlib AddnewInput".
I also installed the latest flash player.
I checked that NET framework 3.5 SP1 is installed + Windows 7 64bit.
Any ideas, what is the problem?
#2 Posted : Friday, April 8, 2011 4:40:17 PM(UTC)
Was thanked: 4801 time(s) in 1648 post(s)
Looks like the flash installation is corrupt somehow.
I have tested vMix 2011 Beta 3 on Windows 7 x64 using the latest Flash Player for Internet Explorer (10,2,153,1) (you can test your flash version here: http://www.adobe.com/software/flash/about/ (use internet explorer if you usually use another browser))
dundurs
#3 Posted : Friday, April 8, 2011 5:19:16 PM(UTC)
dundurs
Thanks, problem solved. I had flash installed, but not the IE version. Actually IE was removed :)
Similar Topics
mscorlib error with flash swf?.. (General Discussion)
by alexsunny123 10/21/2020 7:01:18 PM(UTC)
