HarleyHaynes
#1 Posted : Tuesday, January 23, 2018 8:30:57 PM(UTC)
HarleyHaynes
I have a Nvidia GT1030 card with 2gb ram. I am testing vmix currently and pretty sure I am going to purchase the HD version. Just wondering if I need to upgrade to perhaps a GTX1050?
I am using a C920 webcam and a Behringer Q802 Mixer for audio.
The Computer is HP Elite Desk I7 4790@ 3.60gh
16GB Memory
Windows 10
Nvidia GT1030 2GB
Virtually no load when streaming but I am also getting an odd video glitch during the live broadcast which I have not began troubleshooting other than Upgrading the Nvidia drivers today to 390.65
FFMPEG.Exited
libswresample 2. 0.100 / 2. 0.100
libpostproc 54. 0.100 / 54. 0.100
Guessed Channel Layout for Input Stream #0.1 : stereo
Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio':
Duration: N/A, start: 1736.355000, bitrate: 1536 kb/s
Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1280x720, 29.97 tbr, 10000k tbn, 29.97 tbc
Stream #0:1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
[tcp @ 06af9700] TCP Buffer has been set to 6571008 bytes
[nvenc @ 06afa720] Failed loading the nvenc library
Output #0, flv, to 'rtmp://live-api.facebook.com:80/rtmp/984706795017348?a=ATjpp42dzAniGsro':
Stream #0:0: Video: h264, none, q=2-31, 128 kb/s, 29.97 fps
Metadata:
encoder : Lavc57.3.100 nvenc
Stream #0:1: Audio: aac, 0 channels, 128 kb/s
Metadata:
encoder : Lavc57.3.100 libfaac
Stream mapping:
Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (nvenc))
Stream #0:1 -> #0:1 (pcm_s16le (native) -> aac (libfaac))
Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
HarleyHaynes attached the following image(s):
Cpilcher
#2 Posted : Tuesday, January 23, 2018 9:47:52 PM(UTC)
Cpilcher
Views messages in topic : 323
I am not familiar with that error, but Nvidia runs some processes in the background called Shadowplay, if you disable those background processes it frees up a lot of GPU power in vmix. I would dig through your running processes and remove anything related to Nvidia Share / Shadowplay. This may not be your main problem, but I was receiving high render times as well as frame skips before I removed those processes.
CPilcher
thanks 1 user thanked Cpilcher for this useful post.
HarleyHaynes on 1/24/2018(UTC)
HarleyHaynes
#3 Posted : Wednesday, January 24, 2018 12:46:00 PM(UTC)
HarleyHaynes
CPilcher
I will check that but I did not install the Geforce Experience software. I may do a fresh install of Vmix and the Nvidia driver, or see if I can swap out the graphics card. I am on the trial version is there any limitations on Hardware rendering on the trial version?
Cpilcher
#4 Posted : Wednesday, January 24, 2018 1:48:48 PM(UTC)
Cpilcher
No the trial should be the Full working PRO version. If you didn't install GeForce Experience, you shouldn't have to worry about the background processes. I believe vMix recommends the 1050 rather than 1030. But I run with a 970 and it does just fine... with just a webcam and mixer, I would think things should work with your setup.
CPilcher
HarleyHaynes
#5 Posted : Friday, January 26, 2018 9:54:47 PM(UTC)
HarleyHaynes
GT1030 does not support NVENC
This is straight from the Nvidia Developers forum. Could this be my problem?
HarleyHaynes
#6 Posted : Friday, February 2, 2018 4:52:43 PM(UTC)
HarleyHaynes
Replace with an EVGA GTX1050 and now I get no issues with Hardware rendering.
