I have a Nvidia GT1030 card with 2gb ram. I am testing vmix currently and pretty sure I am going to purchase the HD version. Just wondering if I need to upgrade to perhaps a GTX1050?
I am using a C920 webcam and a Behringer Q802 Mixer for audio.
The Computer is HP Elite Desk I7 4790@ 3.60gh
16GB Memory
Windows 10
Nvidia GT1030 2GB
Virtually no load when streaming but I am also getting an odd video glitch during the live broadcast which I have not began troubleshooting other than Upgrading the Nvidia drivers today to 390.65
FFMPEG.Exited
libswresample 2. 0.100 / 2. 0.100
libpostproc 54. 0.100 / 54. 0.100
Guessed Channel Layout for Input Stream #0.1 : stereo
Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio':
Duration: N/A, start: 1736.355000, bitrate: 1536 kb/s
Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1280x720, 29.97 tbr, 10000k tbn, 29.97 tbc
Stream #0:1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
[tcp @ 06af9700] TCP Buffer has been set to 6571008 bytes
[nvenc @ 06afa720] Failed loading the nvenc library
Output #0, flv, to 'rtmp://live-api.facebook.com:80/rtmp/984706795017348?a=ATjpp42dzAniGsro':
Stream #0:0: Video: h264, none, q=2-31, 128 kb/s, 29.97 fps
Metadata:
encoder : Lavc57.3.100 nvenc
Stream #0:1: Audio: aac, 0 channels, 128 kb/s
Metadata:
encoder : Lavc57.3.100 libfaac
Stream mapping:
Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (nvenc))
Stream #0:1 -> #0:1 (pcm_s16le (native) -> aac (libfaac))
Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
HarleyHaynes attached the following image(s):
(7kb) downloaded 4 time(s).You cannot view/download attachments. Try to login or register.
