stevespaw
#1 Posted : Saturday, January 6, 2018 10:52:39 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
I know that this was implemented a few versions ago, but it is now not working.
Even though I have not checked "allow Multiple instances" I can launch more vMixes at will in the lastest versions.
This is an issue for new non technical users.
Bug?
Thanks,
Steve
#2 Posted : Saturday, January 6, 2018 11:10:27 AM(UTC)
Was thanked: 4734 time(s) in 1624 post(s)
Hi Steve,
I can confirm it is still working as of the latest update.
(It will show the splash screen when opening twice but jump to the original instance and close down)
Double check multiple instances isn't enabled in Settings.
stevespaw
#3 Posted : Saturday, January 6, 2018 3:31:05 PM(UTC)
stevespaw
Have tried it on 3 machines today.
Launching vMix from desktop icon, launches another new version with 2 blank inputs.
Double checked the settings on each.
Steve
#4 Posted : Saturday, January 6, 2018 9:30:39 PM(UTC)
What version? I can't replicate it here on 20.0.0.46 on a few machines.
Maybe someone else can try and confirm.
ask
#5 Posted : Sunday, January 7, 2018 12:08:51 AM(UTC)
ask
Checked on multiple systems...works as expected. As Martin has suggested, you may have the "enable multiple instances" checked even though you believe it to be off.
corporatejames
#6 Posted : Sunday, January 7, 2018 7:35:46 AM(UTC)
corporatejames
admin wrote:
Hi Steve,
Yeap can confirm it working as Martin said above.
stevespaw
#7 Posted : Sunday, January 7, 2018 1:17:09 PM(UTC)
stevespaw
OK I went to the same PC's checked the "multiple instances allowed" box, restarted vMix and same behavior.
Then Unchecked and restarted and now it works as expected.
HMMM, but all is well.
Thanks everyone,
Steve
bcvideo
#8 Posted : Tuesday, February 13, 2018 6:59:30 PM(UTC)
bcvideo
I have noticed that an unchecked "allow multiple instances" box will inhibit opening any more instances only once the first instance has launched completely (past the splash screen).
If you try to launch two instances at the exact same time from the Windows desktop, two or more instances will still launch.
We've had issues with two instances of vmix opening if an operator double clicks the app icon two times, if the splash screen for the first instance had not appeared yet (sometimes it takes a few seconds). This ends up causing issues with blackmagic input/output on both instances.
