Hardware Compatibility
Pci lanes question: 7700K + MSI Z270 Gaming or 5820K and X99 MPower
Joined: 11/29/2016(UTC) Posts: 75  Location: Italy Thanks: 1 times Was thanked: 4 time(s) in 3 post(s)
Hi all, I need to ingest 6 camera inputs using 3 different cards by Blackmagic and 1 from USB by Elgato HD60S:
1) Decklink Duo 2 2) Decklink Mini Recorder 3) Decklink Studio 4) Elgato HD60S
Z270 Gaming 7 with 7700K can handle these 3 cards on PCI lanes? GPU is Asus 1060 - 6GB ram
Otherwise the other option is a MSI X99MPower with 5820K.
The z270 with 7700k should handle it without any troubles. Do not use the x99, this chipset is a nightmare for vmix. Just use the search function and you will see many threads of 7700k users and x99 horror stories.
