camea connection problum in vmix hd version
hello all seniors I am newbee in forum, I have purchased HD version of vmix and trying to connect my handycam and my camera but I am getting error I am using my Hauppauge Capture device and when I try to add camera in vmix getting error as ADD NEW INPUT. THE FOLLOWING ARE SUPPORTED 720X480 NTSC 29.97P CXF2 UNSPECIFIED ERROR. I TRY IN SETTINGS BUT SAME PROBLUM EXSIST.
PLESE GUIDE ME WHERE ARE I AM DOING WRONG ////////??????????
thanks brother for your kind reply but I have try also a capture card as "ezcap HD1080 video capture along with AVERMEDIA SOFT But this device is also not working any advice for which device you will suggest me plese thanks
You also mention AverMedia soft(ware). Do you have an AverMedia capture device? Not sure what the EZCap device is, but perhaps this is it: https://www.amazon.com/Capture-e...P-Recorder/dp/B00KMTYPXCThough it could possibly work, it's not on the Supported Hardware page. I have a knock-off Magewell USB capture device. It works sometimes with vMix perfectly, and the next time, nothing but error messages. Maybe there's an output setting from your HandyCam that will work. What is the model number of the Sony HandyCam you are using?
