Feature Requests
Re-edit multi camera shoot
Joined: 7/9/2016(UTC) Posts: 5   Location: Binghamton, NY
I have 4 cameras recording simultaneously. Oh how I wish I could synchrnize playback of all 4 streams and record reults as if it were a live stream. That way I can go on location with my 4 cameras and bring the results back into vMix after the event.
Joined: 3/17/2013(UTC) Posts: 235  Location: Indiana Thanks: 95 times Was thanked: 30 time(s) in 28 post(s)
Bob Greaves wrote:I have 4 cameras recording simultaneously. Oh how I wish I could synchrnize playback of all 4 streams and record reults as if it were a live stream. That way I can go on location with my 4 cameras and bring the results back into vMix after the event. Bob Greave, you can edit multi cameras in Cyber Link Power Director post video editor. Multi Camera Video & Audio Sync https://youtu.be/wItCEXNvE_0Multi-camera (video) sync is pretty easy to do with Power Director video editor. ~George
@ Bob Greaves
It might be a bit of a tedious process, but it should be possible to accomplish this with vMix. If you can input and playback the recorded files in vMix you should be able to establish a "sync" point (best if documented at onset of recording at event) and Mark that as the IN point of each video. Set-up a shortcut to start all videos simultaneously and be sure they are set-up in vMix to play continuously. Then it is just a matter of cutting between and among them.
Feature Requests
