Instant Replay
Shortcut to save different events
I know this is most likely a noob question, but after going through the manual and trial and error, I'm at a loss.
Here's what I want to do for replay.
Have keyboard shortcuts for different events, for example, a home team goal, the button would take a 10 second clip, and save it as event 1. But a visiting team goal it takes a 10 second clip and saves to event 2.
I know how to make the 10 second clips, with MarkInOutLive shortcut, but how do I get it to save to the right event, so if later on, I want to see a playlist of all the Home team goals, I go to event 1, and play all.
Joined: 10/13/2012(UTC) Posts: 1,162  Location: Melbourne Thanks: 220 times Was thanked: 199 time(s) in 181 post(s)
This is not how the replay works. You will need to add tags to the clip to identify home and away teams. However you can move clips to different lists. It may be possibe (I haven't tried it yet but will) to set the tag via a shortcut (ReplaySetLastEventText) and then select the list (ReplaySelectEvents1,2,3,4,5,6,7,8) after moving the clip (ReplayMoveLastEvent) My thinking is that you would stack the shortcut with multiple commands https://www.vmix.com/hel...m?MultipleShortcuts.htmlHave a play with that and lets us know how you get on.
ask wrote:This is not how the replay works. You will need to add tags to the clip to identify home and away teams. However you can move clips to different lists. It may be possibe (I haven't tried it yet but will) to set the tag via a shortcut (ReplaySetLastEventText) and then select the list (ReplaySelectEvents1,2,3,4,5,6,7,8) after moving the clip (ReplayMoveLastEvent) My thinking is that you would stack the shortcut with multiple commands https://www.vmix.com/hel...m?MultipleShortcuts.htmlHave a play with that and lets us know how you get on. I think I understand what you're getting at. Save clip, set text as HOME GOAL Select events 2 then MoveLastEvent What this does if I understand is rename the clip, then move it to another list. Am I on the right path? I come from a traditional broadcast environment, and this replay system is a little foreign to me in how it works, so I'm trying to make the crossover.
Instant Replay
