djrappa
#1 Posted : Tuesday, December 5, 2017 8:56:29 PM(UTC)
djrappa
Hi
Have a project where Barix Instreamer units will be used to encode an audio source onto a RTP stream on a local area network.
Has anyone had success or is it possible to pickup this stream as an Input Source in vMix?
The only issue I am seeing is Barix quotes its formats as wither G.711, PCM or MP3 where as vMix is specifying AAC or H.264.
Thanks everyone
kjones9999
#2 Posted : Sunday, December 10, 2017 2:40:55 AM(UTC)
kjones9999
You have been a member since:: 8/20/2014(UTC)
The easiest way to do this is create a player using the barix url, then just add the webpage to vmix...
djrappa
#3 Posted : Sunday, December 10, 2017 9:33:05 AM(UTC)
djrappa
Yes but will vMix be ok with the mp3 encoded stream from the Barix?
kjones9999
#4 Posted : Sunday, December 10, 2017 11:25:35 PM(UTC)
kjones9999
generally speaking, it will play any audio coming from the webpage....
SportsNetUSA.net
#5 Posted : Sunday, December 10, 2017 11:48:13 PM(UTC)
SportsNetUSA.net
kjones9999's solution should work.
If you have Instreamer devices, do you also have a Barix Exstreamer unit?
djrappa
#6 Posted : Saturday, December 23, 2017 1:36:30 AM(UTC)
djrappa
Yes for testing purposes, but I don't desire using an Extreamer to feed the analogue audio in to Vmix, to me thats an antiquated and backwards solution.
SportsNetUSA.net
#7 Posted : Saturday, December 23, 2017 3:25:11 AM(UTC)
SportsNetUSA.net
Very true, that would be antiquated. Just wondering if you had an Exstreamer. I used to use Instreamers, Annuncicoms and Exstreamers years ago, but software solutions came along ending their use.
djrappa
#8 Posted : Saturday, December 23, 2017 4:00:24 AM(UTC)
djrappa
We've used them as standalone players on a few jobs where there was a desire for a non PC solution.
For jobs like this one I like to have one specced as a bit of a get out of jail card for when someone says the stream isn't sending so you can show the problem isn't on your end.
kjones9999
#9 Posted : Tuesday, December 26, 2017 8:29:41 PM(UTC)
kjones9999
So the issue here is that you have MP3 audio that needs to be read by vmix, and that just does not occur natively. You could mux it with a blank video stream and add it as flash but thats way too much trouble.
djrappa
#10 Posted : Tuesday, December 26, 2017 8:36:39 PM(UTC)
djrappa
I'll have the hardware this week and can test. I think the solution above of using a basic generated web page will probably achieve the goal.
