Joined: 10/31/2017(UTC) Posts: 26  Location: Marina del Rey, CA Thanks: 2 times
Is there any way we can effectively INVERT the mask created by the chroma key so that in essence we could fill the "non green" area instead of the other way around?
No, but you can take a screen shot and do so in photoshop.
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
This may be possible with a big workaround but before I try it would shooting the foreground as a black silhouette ie no foreground lighting to create a matte work for what you want ?
An invert button on the keyers would be useful.
Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 320 times Was thanked: 263 time(s) in 233 post(s)
I've occasionally wished that a matte invert was available. It's not practical to Photoshop something that isn't a still image. Very tedious to create an inverted matte for an existing video file.
