Feature Requests
Take image snapshot of output or preview
Joined: 6/16/2013(UTC) Posts: 15   Location: Netherlands,Lelystad Thanks: 27 times Was thanked: 1 time(s) in 1 post(s)
A lot of times i use the preview screen to make a template image. It would be nice if i can use the snapshot tool on the preview so i not have to put it on the mainscreen for capture (during show this is not possible ;-))
After some research i discovered it was available when using shortcuts. But that option is removed :-( or i do not have this option for another reason :-(
You have been a member since:: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 76 time(s) in 57 post(s)
I have had a couple of people ask about image capture of "preview" window. This would be way more useful than program actually.
vMix 20? :-)
I also do not see the image capture shortcuts in the list.
Steve
 1 user thanked stevespaw for this useful post.
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Quote:I also do not see the image capture shortcuts in the list. Snapshot under output ?? V.54
doggy wrote:Quote:I also do not see the image capture shortcuts in the list. Snapshot under output ?? V.54 Thanks, I see it now. Thanks! If only I could select the source it would be perfect. !!!!
Snapshot is only for program, not preview :-( In the manual it say you can choose any source.
Joined: 8/2/2013(UTC) Posts: 1,095   Location: Fairhope, Alabama USA Thanks: 587 times Was thanked: 202 time(s) in 168 post(s)
doa wrote:In the manual it say you can choose any source. Do not see that. Please reference. - Tom
Maybe this could be achieved by extending the SNAPSHOT shortcut function to allow the Input to be specified. Currently the only value that can be used is for the filename to save as.
Joined: 3/7/2012(UTC) Posts: 2,690  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ doa Unfortunately, the screenshot from that thread is a little misleading... It is a valid request (in both this and that thread) to have more options for the "Snapshot" function. But AFAIK, it has always just been for the Output screen (as it is currently in vMix 19.0.0.54):  Perhaps support can be added to one or the other, or maybe the two threads can be combined by an administrator for better tracking of this Feature Request. Ice
Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
[img][/img] Dear, Any idea why I only get a black pictures as output ? Still no way to snapshot the preview or an input ? Johan JohanSpijker attached the following image(s):  snap.JPG (45kb) downloaded 7 time(s).You cannot view/download attachments. Try to login or register.
+1 again, this is still a common request, snapshots of "program" are just not that useful.
Steve
Quote:snapshots of "program" are just not that useful. beg to differ
Can someone explain how the snapshot of the output works, I get only black pictures. What must i fill under value ?
Joined: 4/18/2016(UTC) Posts: 223 Location: United Kingdom
Thanks: 33 times Was thanked: 37 time(s) in 31 post(s)
doggy wrote:Quote:snapshots of "program" are just not that useful. beg to differ I think this very much depends on what you're doing, for news and sport the ability to grab still frames from program while broadcasting is very useful. If you're doing something like shopping TV, the ability to grab a product shot on preview out of vision is also very useful.
I found out that it grabs always output 1, is this correct ? Can this be changed ?
Because since v20 you can patch a input as source for a output (1-4).
 1 user thanked JohanSpijker for this useful post.
I use sharex to automatically tweet the program snapshot with a shortcut... this shows the score. Once capturing the program output, sharex detects a change in the folder and tweets without intervention.
 1 user thanked kjones9999 for this useful post.
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
+1 to other sources but also having an input type that uses the last snapshot as a source.
Thanks: 5 times Was thanked: 8 time(s) in 8 post(s)
+1 to other sources (preview or external outputs)
 1 user thanked kol0 for this useful post.
Joined: 11/23/2016(UTC) Posts: 330  Location: USA Thanks: 179 times Was thanked: 26 time(s) in 25 post(s)
+ 1 to any source. And any input.
 1 user thanked rowby for this useful post.
Feature Requests
