oakwood99
#1 Posted : Friday, November 24, 2017 11:50:31 AM(UTC)
oakwood99
I recently updated V-Mix to 20.0.0.42 from the previous version. Previously I was running my GH4 4K through the epiphan video AV.IO 4K with great results. My setup hasn't changed or the camera settings. All that has changed is, the updated to V-Mix. Is this video capture hardware still supported? I get the following error when setting up the camera:
AddNewinput
Capture Device is Not Suported. Device Reported the following; Capture
oakwood99 attached the following image(s):
#2 Posted : Tuesday, November 28, 2017 8:58:36 PM(UTC)
I can confirm no capture changes have been made in the latest vMix update.
The error indicates the AV.IO 4K is not accepting connections for some reason, try
loading it into something like VLC to see if there isn't an issue with the device.
Also try a different USB port if possible.
RobLambert
#3 Posted : Saturday, December 2, 2017 10:56:14 AM(UTC)
RobLambert
Did this get figured out! I was thinking of getting the exact same dongle.
Thank you very much.
