Thanks: 32 times Was thanked: 2 time(s) in 2 post(s)
Hi guys! I upgraded to vMix 20 two weeks ago and since I updated the audio output of vMix is distorted. I have done tests of different types and it always comes out distorted, I have come to the conclusion that it is vMix because if I use the external output and I use it with OBS the audio of the Team Speak leaves without distortion to the air however if I do not use the OBS all the audio is distorted. I have not made any changes to the audio configuration, in fact the audio in my headphones is clean and correct. I am using an HD60 PRO capture card from Elgato Gaming and as I said before the audio in my headphones is perfect but when going on the air it is distorted, the same thing happens to me when I put a video in vMix, in my headphones it sounds good but on air It is distorted. Something I do not understand well is why the audio of my microphone that is heard through vMix is heard perfectly but the audio of the capture card, videos and songs are distorted. Here are two examples so you can see the difference between using vMix 20 and vMix 19: vMix 20: ?t=7 vMix 19: https://www.youtube.com/...hN-IuPbwZ70&t=1375s I hope someone can help me, I do not know if it is listening to the double audio or it is a distortion. By the way, in both cases the external output of vMix was being used and broadcasting to YouTube from OBS Thanks in advance!
Joined: 1/13/2010(UTC) Posts: 5,350  Location: Gold Coast, Australia Was thanked: 4754 time(s) in 1632 post(s)
It sounds very much like doubled audio slightly out of sync with eachother. Try a test recording in vMix itself, if the audio there is fine, then the external program must be duplicating the audio, perhaps if it is OBS, you have both the system audio and the vMix audio device enabled.
Martin vMix
Just a question why are using OBS when you have Vmix and can do all in Vmix? What task are using OBS for that Vmix can not do for you? or did miss something?
@ pasingshot
Maybe I've missed something, or my system doesn't pick it up, but I don't hear any distortion or double audio on my end in the vMix 20 YouTube link, which leads me to believe this might be a YouTube encoding thing or alternatively, a system's settings or Windows thing. The vMix 19 link is bad (404 not found error).
admin wrote:Hi,
Martin vMix Thanks guys, it was a duplicated audio, solved!
corporatejames wrote:Just a question why are using OBS when you have Vmix and can do all in Vmix? What task are using OBS for that Vmix can not do for you? or did miss something? I do not why but the video recorded with vMix is a little bit worst and have micro freeze, with OBS I have no problems. Who knows why!
IceStream wrote:@ pasingshot
Thanks Ice, I found the problem and solved it with admin advice. The distortion was with vMix 20 no with 19 jejejeje Thanks again mate!
