bluepk
#1 Posted : Monday, November 20, 2017 5:58:54 AM(UTC)
bluepk
Hello!
I have a problem with the title file. The text disappears as if there was a margin. How to remove it, reduce it?
#2 Posted : Monday, November 20, 2017 7:05:14 AM(UTC)
Reduce the font size if you want both lines or enlarge (longer) the text fiels in the xaml code of the title
Basically the field is to small for the amount of text you wont to put in
bluepk
#3 Posted : Monday, November 20, 2017 7:17:43 AM(UTC)
bluepk
The problem occurs here. As I move the text line up, it shows up. I still have a question about the effect of the input. I have a demo of the left and right input demos. Can modify the effect time. The input is long, the file shows 1 second. I tried to make 0.5 and nothing.
#4 Posted : Monday, November 20, 2017 7:52:12 AM(UTC)
Sorry , your explanation is confusing to me
Mari
#5 Posted : Monday, November 20, 2017 1:25:41 PM(UTC)
Mari
Netherlands
... simply use smaller font size... like posted earlier...
