Hello! I have a problem with the title file. The text disappears as if there was a margin. How to remove it, reduce it?
Reduce the font size if you want both lines or enlarge (longer) the text fiels in the xaml code of the title
Basically the field is to small for the amount of text you wont to put in
The problem occurs here. As I move the text line up, it shows up. I still have a question about the effect of the input. I have a demo of the left and right input demos. Can modify the effect time. The input is long, the file shows 1 second. I tried to make 0.5 and nothing.
Sorry , your explanation is confusing to me
Joined: 2/14/2016(UTC) Posts: 118  Location: Oss Thanks: 12 times Was thanked: 15 time(s) in 14 post(s)
... simply use smaller font size... like posted earlier...
