3 Pages123>
#1 Posted : Thursday, May 23, 2013 8:22:30 AM(UTC)
Was thanked: 4719 time(s) in 1617 post(s)
vMix 10 is now well on the way to being completed!
Below is a preliminary list of the new features that will be available:
* New Output Options
-Two indendently configurable outputs, 1. Fullscreen 2. Recordings and External Output
-These Two outputs can be set to one of the following:
--Output
--Preview
--MultiView (top half of screen Preview/Output, bottom half first 8 inputs)
--Input (for example, configure fullscreen to show a single camera while recording the master mix)
-If both outputs are set to Output, the four Overlay channels can be configured independently.
* Improved RTSP compatibility.
-I have been given various test streams from cameras and servers that were having issues and implemented fixes. (Including Panasonic and Vivotek)
* Support for Transport Streams (H264/AAC)
-This can be used with the Teradek Bond / Sputnik etc
* New API options
-Designed to assist with external scheduling apps and hardware controllers
-GUID support, Loop toggle, extended XML information
* Multiple Hard Drive support for Multicorder
* Default settings button
Feel free to comment below.
thanks 4 users thanked admin for this useful post.
watchfulone on 5/23/2013(UTC), Yaamin on 5/23/2013(UTC), madness on 5/30/2013(UTC), kkr on 6/1/2013(UTC)
Henny
#2 Posted : Thursday, May 23, 2013 10:08:10 AM(UTC)
Henny
Was thanked: 28 time(s) in 24 post(s)
Hi all
Having spent the past month evaluating vmix as a mix solution for verious projects I think most of the shortcomings have been covered with this update.
One thing I would like to add to the wish list is a web page I put where you can enter a URL and use the page as an input, I would use this for things like twitter/Facebook feeds as well as other data
dundurs
#3 Posted : Thursday, May 23, 2013 10:50:10 AM(UTC)
dundurs
Was thanked: 46 time(s) in 23 post(s)
Our broadcasting teams would very much appreciate if resolution for Decklink and External Output could be set independently. Decklink driver only accepts standardized resolutions such as 720x576, but want to use a different resolution for External Output (for example 1024x576) to minimize FMLE CPU consumption (and FMLE is a great CPU eater when it comes to video resize). Sometimes we want to use 1280x720 50i for External Output and 720x576 for Decklink Output, but we end up using 1920x1080 50i for both and FMLE CPU consumption goes nuts since it has to encode Full HD or resize.
Basically this feature would allow much more efficient use of CPU resources making the system more stable and capable, so please make this happen, if possible.
Dundurs
watchfulone
#4 Posted : Thursday, May 23, 2013 4:43:01 PM(UTC)
watchfulone
Was thanked: 17 time(s) in 14 post(s)
--Output
--Preview
* New API options
Can't wait for this version to release, excellent job Martin by the next NAB 2014 vMix will be one of the video TOP if not the top video switcher software. God bless you Martin
Yaamin
#5 Posted : Thursday, May 23, 2013 6:32:49 PM(UTC)
Yaamin
VMIX needs a Character generator,martin would you please include a character generator to the new edition.currently it's very difficult to handle titles and there is no RSS feeds to be inputted.it would be a boost to vmix having a character generator.thanks
Damn2Good4U
#6 Posted : Thursday, May 23, 2013 6:50:54 PM(UTC)
Damn2Good4U
+1for the character generator
I think, the version 10 should save our last working preset... What do I mean by this?
If I have a Working preset set, and all worked well for me... When next I switch on my pc and load vMix, vMix should automatically load my last working preset instead of having to press a button to doing so.
RSS feed to generate updated newsfeed as a scroller, will be an added advantage and if possible a graphically generated weather feed as part of the lower third in the right hand corner.
Rottimmy
thanks 1 user thanked Damn2Good4U for this useful post.
Yaamin on 5/24/2013(UTC)
macgiver76
#7 Posted : Thursday, May 23, 2013 9:39:16 PM(UTC)
macgiver76
Thanks Martin for all the work, for me multicorder on separate drives is very important.
If it were possible to use network drive with a lan 1000 would be great.
ngaanyatjarramedia
#8 Posted: : Thursday, May 23, 2013 9:55:41 PM(UTC)
ngaanyatjarramedia
Sounds great! Thanks for your hard work.
@ Macgiver76
Can't you just map a network drive to something like Z:?
#9 Posted : Thursday, May 23, 2013 11:18:00 PM(UTC)
Not sure what is meant by a Character Generator, in vMix you can already edit the text, change font, colour etc.
khanhtrung
#10 Posted : Thursday, May 23, 2013 11:27:22 PM(UTC)
khanhtrung
vMix 10 need T Bar, open parameters (source) T bar, we will hardware fabrication for T bar, Thanks !
macjaeger
#11 Posted : Friday, May 24, 2013 12:00:42 PM(UTC)
macjaeger
admin wrote:
* New API options
I'm especially thrilled about these additions, they are coming at exactly the right time! I'm going to work on our external scheduler project during the upcoming weekend(s), and having
GUID support will save me a lot of extra code, and will make the scheduler more efficient (only half as many api-calls) and less error prone than my proof-of-concept code ;-)
Thank you for the open ear you extend to your user community!
Yaamin
#12 Posted : Friday, May 24, 2013 5:20:22 PM(UTC)
Yaamin
Vmix currently is very much user friendly thanx for that but still text,and scrolls are not able to insert RSS feeds.we would like to see a advanced character generator for vmix.and also thanx for all vmix team
kayllastudio
#13 Posted : Saturday, May 25, 2013 3:43:33 AM(UTC)
kayllastudio
Was thanked: 12 time(s) in 7 post(s)
example character generator
thanks 1 user thanked kayllastudio for this useful post.
Yaamin on 5/25/2013(UTC)
macjaeger
#14 Posted : Saturday, May 25, 2013 10:14:33 AM(UTC)
macjaeger
admin wrote:
* New API options
I'd like to use the extended API in my scheduling project. Is there a beta version available for download? Or an explanation of the new API? Or may I just assume it works like we discussed in the thread about scheduling?
Yaamin
#15 Posted : Sunday, May 26, 2013 4:03:56 PM(UTC)
Yaamin
Since vMix has a scroll bar, I would like to see that the scroll speed can be adjusted.
I also would like to see that RSS feeds could translate into the scroll bar. It would be a great help when severe weather approaches or for breaking news. It would be great if I could take the RSS feed from the National Weather service and put it straight to the scroll.
Thank you for considering this. i would like very much to see an Arabic direction scroll bar too
Damn2Good4U
#16 Posted : Sunday, May 26, 2013 4:10:29 PM(UTC)
Damn2Good4U
Can "Skype Video Capture" be added to the v10 please?
Adding Skype video to ones broadcast without using screen capture. With this function, broadcasters can get the video feeds directly from Skype or Oovoo.
This will be helpful for when you have to interview someone in a remote location.
Rottimmy
Yaamin on 5/27/2013(UTC)
ridi
#17 Posted : Monday, May 27, 2013 6:23:21 PM(UTC)
ridi
may you improve the palylist, to add te calculate the time, and to begin a film that puts hours I. Thank you
Damn2Good4U
#18 Posted : Monday, May 27, 2013 6:55:08 PM(UTC)
Damn2Good4U
@Macjaeger is currently working on this... see http://forums.vmix.com.a...osts&m=4687#post4687
Rottimmy
macjaeger
#19 Posted : Monday, May 27, 2013 7:11:32 PM(UTC)
macjaeger
I've got a scheduling application in the pipeline that can "remote control" vMix. It will allow you to use vMix as a broadcasting application, e.g. serving clips, slideshow and other content to the internet. This may not be what you need, it's hard to tell from your short request. Perhaps you could add your request to the "feature request" forum and elaborate?
ridi
#20 Posted : Tuesday, May 28, 2013 2:49:54 PM(UTC)
ridi
Iam not good with english, but i want to say a playlist like Airbox or MagicSoft PlayOut. Thank you.
3 Pages123>
