Feature Requests
Replay playout to separate output
Thanks: 23 times Was thanked: 10 time(s) in 7 post(s)
I´d really like to be able to playout the content of the replay system to a separate (physical) output... I could´t find a way to do so... but maybe I overlooked something?
Thanks: 38 times Was thanked: 39 time(s) in 35 post(s)
Just set the second external output to the input number of your replay input.
 1 user thanked Rinsky for this useful post.
Rinsky wrote:Just set the second external output to the input number of your replay input. hmmm... I´m already using the 2nd output to record a certain camera... So I would have to change my request to "more outputs" :-) But this is already a request! But thanks for your help, didn´t see that I could do that... Could I set the replay output to one of the NDI Outputs and record this on another computer, maybe? (Is it possible to record an NDI stream with, let´s say the capture function of Premiere Pro?) Greetings, Thomas
Joined: 5/13/2014(UTC) Posts: 519   Location: Manchester, UK Thanks: 2 times Was thanked: 183 time(s) in 130 post(s)
Harty wrote:(Is it possible to record an NDI stream with, let´s say the capture function of Premiere Pro?) No, not in Premiere, but it is possible via NewTek's NDI IsoCorder app.
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
There's the 2nd fullscreen output, not sure if it supports audio, if not put the camera on it and use Ext2 for the replays.
Feature Requests
