Good morning! I am new here. I saw a topic on this subject, but there was no solution. Is it possible to open a live YouTube stream as input in vMix? I tried by "Input > Stream > RTMP", but it is just a stop-frame.
Hi You can PLAY any video from YouTube in vMix using the Flash/RTMP input type with this syntax : http://www.youtube.com/v/VIDEO_ID or you can use the webbrowser input too Guillaume
Joined: 12/27/2012(UTC) Posts: 5,474  Location: Belgium Thanks: 313 times Was thanked: 1013 time(s) in 832 post(s)
@ Dwam
mentioned it last week in a post that i haven't been able to get a YT video or stream via Flash/RTMP anymore !!
in fact , when one clicks on the iput the browser opens up to the video
I tested with Flash / RTMP and opened the browser.
Quote:mentioned it last week in a post that i haven't been able to get a YT video or stream via Flash/RTMP anymore !! in fact , when one clicks on the iput the browser opens up to the video Just tried... Yep doesn't work no more indeed... ? The WebBrowser input method works though... Not as nice but works perfectly
More about it : when ticking the "url includes app instance" box, then something shows up. Unfortunately the image indicates the reason why it no longer works. Makes sense btw... DWAM attached the following image(s):  vMix Capture 13 novembre 2017 18-12-41.png (1,281kb) downloaded 18 time(s).You cannot view/download attachments. Try to login or register.
Another working solution is to play the video in VLC with NDI plugin
 2 users thanked DWAM for this useful post.
VLC is unreliable. When it loses its connection for milliseconds, it throws a black image and does not connect again. Has anyone tried to extract from YT the rtmp address for transmission? Maybe it is possible?
just download the videos and play them locally then
I wrote, it's about live broadcasts. It is up to me to buy rtmp server, only offer up to 3mbps. Not too much.
