stampersplus
#1 Posted : 8 years ago
stampersplus
So now testing FB Live and get this message:
FFMPEG.Exited
Last message repeated 3 times
[dshow @ 011283a0] real-time buffer [vMix Video YV12] [video input] too full or near too full (68% of size: 256000000 [rtbufsize parameter])! frame dropped!
Last message repeated 1 times
[dshow @ 011283a0] real-time buffer [vMix Video YV12] [video input] too full or near too full (69% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 011283a0] real-time buffer [vMix Video YV12] [video input] too full or near too full (70% of size: 256000000 [rtbufsize parameter])! frame dropped!
Last message repeated 2 times
[dshow @ 011283a0] real-time buffer [vMix Video YV12] [video input] too full or near too full (71% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 011283a0] real-time buffer [vMix Video YV12] [video input] too full or near too full (72% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 011283a0] real-time buffer [vMix Video YV12] [video input] too full or near too full (73% of size: 256000000 [rtbufsize parameter])! frame dropped!
Last message repeated 4 times
[dshow @ 011283a0] real-time buffer [vMix Video YV12] [video input] too full or near too full (74% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 011283a0] real-time buffer [vMix Video YV12] [video input] too full or near too full (75% of size: 256000000 [rtbufsize parameter])! frame dropped!
Last message repeated 13 times
[rtmp @ 04851080] Server error: Initialization failed (2: Broadcast state is bad)
rtmp://live-api-a.facebook.com:80/rtmp/1670009219716791?s_l=1&a=AThJbHE49Z78MOj_: Operation not permitted
[dshow @ 011283a0] real-time buffer [vMix Video YV12] [video input] too full or near too full (76% of size: 256000000 [rtbufsize parameter])! frame dropped!
I am starting get frustrated. It is a great program and I really want it!
thanks 1 user thanked stampersplus for this useful post.
streamworks on 11/14/2017(UTC)
vmixgreg
#2 Posted : 8 years ago
vmixgreg
Rank: Staff
Groups: Registered, Moderator
Was thanked: 19 time(s) in 18 post(s)
The real-time buffer error means that your stream is struggling to keep up. And therefore dropping frames. See the below knowledge base article which helps to diagnose the cause:
http://www.vmix.com/know...mes-show-orange-or-amber
The two most common causes:
1) Streaming at a bitrate too high for your internet upload speed. You can check your upload speed by doing a speedtest:
http://www.speedtest.net/
As a general rule, the Streaming Quality bitrate should be a value less than 80% of the Upload speeds available for the best results. (For example 1.6Mbps on a 2Mbps connection). If you are streaming at a bitrate higher than your upload speed, then it will not work properly.
2) Overloaded or underpowered CPU. A good way to check is by looking at the statistics at the bottom left corner of vMix while streaming to check if it is peaking.
vMixGreg
thanks 1 user thanked vmixgreg for this useful post.
stampersplus on 10/3/2017(UTC)
streamworks
#3 Posted : 8 years ago
streamworks
Hi StamperPlus,
Did you figure out what the problem was? We're experiencing the same problem, only with Facebook Live.
Internetspeed is fine and the CPU is managing.
Cheers,
Mike
vmixgreg
#4 Posted : 8 years ago
vmixgreg
Rank: Staff
Additional information on underatanding and interpreting the streaming logs can be found in this vMix Knowledge Base article:
https://www.vmix.com/kno...ng-ffmpeg-streaming-logs
vMixGreg
