Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Hello fellow vMixers.
I am currently looking for some input on audio boards.
Is anyone currently using a digital board? If so which one and why?
I am personally debating moving over to a rackmount solution like the Behringer x32 Rack or the XR18.
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
I currently using a Behringer Q1204USB, It's ok but I am looking at replacing it with a Behringer UMC404HD.
As the UMC404HD has an advantage of bringing in 4 independent inputs into the computer. As the Q1204USB the inputs are mixed and comes in as 1 input into the computer. Same goes for the X32 and XR18, the inputs are mixed and comes in as 1 input into the computer.
I would look at the Behringer UMC1820 if you want more inputs... If you want to stay with Behringer.
An audio interface is the way to go in my opinion. If I would have known before buying my mixer I would have and Audio interface instead...
There are lots of Audio Interface's out there, all depends on your budget...
Joined: 7/1/2016(UTC) Posts: 48  Location: Italy Thanks: 5 times Was thanked: 4 time(s) in 4 post(s)
Behringer Xenyx UFX1204 is a great Mixer with 16 Channel USB Input
