BluestemVideo
#1 Posted : Friday, November 10, 2017 6:28:52 PM(UTC)
BluestemVideo
Hello fellow vMixers.
I am currently looking for some input on audio boards.
Is anyone currently using a digital board? If so which one and why?
I am personally debating moving over to a rackmount solution like the Behringer x32 Rack or the XR18.
desmar
#2 Posted : Friday, November 10, 2017 7:06:05 PM(UTC)
desmar
Canada
I currently using a Behringer Q1204USB, It's ok but I am looking at replacing it with a
Behringer UMC404HD.
As the UMC404HD has an advantage of bringing in 4 independent inputs into the computer.
As the Q1204USB the inputs are mixed and comes in as 1 input into the computer.
Same goes for the X32 and XR18, the inputs are mixed and comes in as 1 input into the computer.
I would look at the Behringer UMC1820 if you want more inputs... If you want to stay with Behringer.
An audio interface is the way to go in my opinion. If I would have known before buying my mixer I would
have and Audio interface instead...
There are lots of Audio Interface's out there, all depends on your budget...
digitalalps
#3 Posted : Saturday, November 11, 2017 7:46:53 AM(UTC)
digitalalps
Behringer Xenyx UFX1204 is a great Mixer with 16 Channel USB Input
