Instant Replay
"ReplayUpdateSelectedInPoint" Shortcut Bug? (sets to 00:00:00:00)
Joined: 8/15/2015(UTC) Posts: 8 Location: Mobile, AL USA
Has anyone had this happen within the Vmix Replay interface?
When I'm going back through recorded events (that already have set in/out points) and try to use the shortcut command "ReplayUpdateSelectedInPoint" it changes the in point to 00:00:00:00. It does the same if I try to update the out point.
It has me confused, because the same shortcut has worked for several seasons. And it just started to act up last week.
This 00:00:00:00 reset occurs both when I am live or not as well as if I am recording or not.
So I guess I am alone on this one?
Booo! haha
Joined: 3/7/2012(UTC) Posts: 2,691  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ MCPSStv
Where is your playhead positioned when you reset? It is supposed to update the IN point of selected event to the current position, are you using the most recent version of vMix?
Instant Replay
