omnisound
#1 Posted : Saturday, March 19, 2011 9:06:06 AM(UTC)
omnisound
Hello, (sorry for my english, I'm french).
I use the last beta version of Vmix and the free version and I've a problem in the two version when I record with the software :
I connect two camcorder in DV to my PC (OS : win 7) and all are in 16/9 mode squeeze. The destination of video is DVD. The problem is the recorded file is not in 16/9.
Please can you help me?
PS : I love this software and the beta version is perfect. It just left the mpg2 format for recording and more parameters (size in pixels,ratio) for overlay parameters.
Thanks.
melody
#2 Posted : Saturday, March 19, 2011 12:42:27 PM(UTC)
Rank: Guest
Groups: Guests
hi omnisound, think can help you.
what video codec are you using to record?
omnisound
#3 Posted : Saturday, March 19, 2011 12:53:45 PM(UTC)
omnisound
The codec used is AVI - DV Video encoder. I've tested with the WMW codec but no changes. For acquisition it's Microsoft DV VCR.
Thank you for reactivity.
#4 Posted : Saturday, March 19, 2011 4:54:14 PM(UTC)
Due to a bug in the Microsoft DV Codec, you will need to adjust the aspect ratio in post.
This means opening the avi file in a video editing program and adjust the source to say it is 16:9, it will then show with the correct aspect ratio.
For full 16:9 video I recommend using vMix HD Edition with CineForm set to 1280x720 or above.
melody
#5 Posted : Saturday, March 19, 2011 4:56:41 PM(UTC)
Rank: Guest
Groups: Guests
before recording, go settings -> display and set the "Output Size" resolution you want to record.
then, go Record "Setup" option and try to use lagarith codec (i`m using it and i like very much).
i recommend to install this codec before use:
http://lags.leetcode.net/LagarithSetup_1323.exe
note: you need a lot of free disc space to record with this codec.
regards,
melody
omnisound
#6 Posted : Sunday, March 20, 2011 12:02:02 PM(UTC)
omnisound
OK thanks; I'm going to test it !
