emad
#1 Posted : Sunday, November 5, 2017 5:51:31 PM(UTC)
emad
I will by new computer to use for Vmix
is Vmix suit with intel Xeon processor?
I will buy (Dell Precision T5810 Workstation) and the Image below for the specification of the computer.
And wich one is putter to by Dell Precision T5810 Workstation or Dell Alienware ??
emad attached the following image(s):
sinc747
#2 Posted : Sunday, November 5, 2017 10:41:46 PM(UTC)
sinc747
Check out what vMix recommends here: https://www.vmix.com/sof.../supported-hardware.aspx
The Nvidia graphics card is vital.
- Tom
emad
#3 Posted : Monday, November 6, 2017 3:39:08 PM(UTC)
emad
thank you
I do know aware abut the specification needed for the vimix computer put may Maine question is:
do i will face problem with if i use Xeon processor??
SportsNetUSA.net
#4 Posted : Tuesday, November 7, 2017 4:07:10 PM(UTC)
SportsNetUSA.net
Many vMix users have systems that use Xeon processors. That should not be a problem. However, as Tom suggested, you should look to get an Nvidia graphics card. Also, a solid state drive for recordings would be helpful.
fthomas137
#5 Posted : Saturday, November 25, 2017 1:09:03 PM(UTC)
fthomas137
Xeon processors are 100% ok. I'm running a dual xeon motherboard and vmix chimes away nicely.
Frank
