I will by new computer to use for Vmix is Vmix suit with intel Xeon processor? I will buy (Dell Precision T5810 Workstation) and the Image below for the specification of the computer. And wich one is putter to by Dell Precision T5810 Workstation or Dell Alienware ?? emad attached the following image(s):  Untitled.png (106kb) downloaded 9 time(s).You cannot view/download attachments. Try to login or register.
Joined: 8/2/2013(UTC) Posts: 1,100   Location: Fairhope, Alabama USA Thanks: 592 times Was thanked: 204 time(s) in 170 post(s)
thank you
I do know aware abut the specification needed for the vimix computer put may Maine question is:
do i will face problem with if i use Xeon processor??
Many vMix users have systems that use Xeon processors. That should not be a problem. However, as Tom suggested, you should look to get an Nvidia graphics card. Also, a solid state drive for recordings would be helpful.
Xeon processors are 100% ok. I'm running a dual xeon motherboard and vmix chimes away nicely.
Frank
