Hardware Compatibility
Magewell Eco Capture M.2 with H270n mobo (mini-ITX). Is it possible?
Hey guys,
I have a Gigabyte MoBo, GA-H270N-WIFI, a mini-ITX form factor, with a Cooler Master Elite 110 case. I'm about to buy a capture card from Magewell, caled Eco Capture Dual HDMI M.2, but i'm not sure it is compatible with my system.
First question: the conectors are fully compatible? Mobo: 1 x M.2 connector on the back of the motherboard (Socket 3, M key, type 2260/2280 SATA and PCIe x4/x2 SSD support) Magewell: M.2 2280 standard size
Second question: do I have the necessary size in my case to install that? The magewell specs don't talk about the devices size, but as in the pics it apear to be thick, i'm not sure...
Thanks for helping!
Joined: 5/13/2014(UTC) Posts: 520   Location: Manchester, UK Thanks: 2 times Was thanked: 183 time(s) in 130 post(s)
felipelengert wrote: First question: the connectors are fully compatible? Mobo: 1 x M.2 connector on the back of the motherboard (Socket 3, M key, type 2260/2280 SATA and PCIe x4/x2 SSD support) Magewell: M.2 2280 standard size
The socket is the right type, but being underneath the motherboard is probably a no-no, given that the Eco Capture cards have a heatsink ~10mm high which needs adequate ventilation. I guess it depends on the design of your case as to (a) whether there's space for it, and (b) whether that space will get sufficient airflow over the heatsink. I've tested those Eco Capture cards in a full-size ATX Z170 chipset board, in which the M2 slot is on top of the M/B, and can confirm they work fine in vMix, albeit without the direct SDK support that the Pro Capture cards enjoy, not least because the SDK for the Eco cards hasn't been released as yet.
 2 users thanked zenvideo for this useful post.
zenvideo wrote: The socket is the right type, but being underneath the motherboard is probably a no-no, given that the Eco Capture cards have a heatsink ~10mm high which needs adequate ventilation. I guess it depends on the design of your case as to (a) whether there's space for it, and (b) whether that space will get sufficient airflow over the heatsink.
OK, thanks Zenvideo! That's a sad notice... maybe then I have to look for another case layout to make this work, because under my mobo there is no more than 10mm... I dont have any PCIe free in my mobo, and I dont expect to have the same performance in the usb solutions. Any other sugestions?
Thanks: 99 times Was thanked: 5 time(s) in 5 post(s)
Felipelengert,
Did you end up getting the capture card???? What did you end up working out???
RobLambert wrote:Felipelengert,
Thanks Hey Rob, for now im using 2 Elgato hd60s, connected in usb 3.0 ports, but im not happy with the delay.
 1 user thanked felipelengert for this useful post.
felipelengert wrote:RobLambert wrote:Felipelengert,
Thanks Hey Rob, for now im using 2 Elgato hd60s, connected in usb 3.0 ports, but im not happy with the delay. Thank you.... how big is the delay????
