Systems
Any capture card supports GH5 @ 4k60P 4:2:2 10bit?
Thanks: 3 times Was thanked: 13 time(s) in 12 post(s)
Title pretty much explains it all.
I have a GH5 which I want to use for 4k60 + chromakey, and I'm currently figuring out the best possible capture method for it.
It doesnt matter if its HDMI or SDI, as long as it supports "full power"
thanks,
RS
Thanks: 11 times Was thanked: 18 time(s) in 13 post(s)
on paper BM DeckLink 4K Extreme 12G, and DeckLink 4K Pro + Teranex Mini HDMI to SDI 12G. but at the moment we dont have any 12G decklink to check
Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
 1 user thanked droza for this useful post.
Joined: 5/13/2014(UTC) Posts: 520   Location: Manchester, UK Thanks: 2 times Was thanked: 183 time(s) in 130 post(s)
The Magewell Pro Capture HDMI 4K Plus supports the HDMI v2.0 signal standard, which includes 4K60p (obviously), but not every single permutation of colour sampling (4:2:2, 4:2:0, etc) and bit depth (8-bit, 10-bit, etc). I have used it with vMix, and done tests to check it's OK at 4K60p with the output from a graphics card (because I don't have a 4K60p camera).
 1 user thanked zenvideo for this useful post.
dark_ata wrote:on paper BM DeckLink 4K Extreme 12G, and DeckLink 4K Pro + Teranex Mini HDMI to SDI 12G. but at the moment we dont have any 12G decklink to check I had come to the same conclusion... also the magewell 4k60.. End of the day just feels risky to try it "blind" Gonna stick with the 4k30 mini recorder until a decent solution is proven.
Systems
