RandomStreamer
#1 Posted : Friday, October 20, 2017 2:08:35 PM(UTC)
RandomStreamer
Title pretty much explains it all.
I have a GH5 which I want to use for 4k60 + chromakey, and I'm currently figuring out the best possible capture method for it.
It doesnt matter if its HDMI or SDI, as long as it supports "full power"
thanks,
RS
dark_ata
#2 Posted : Saturday, October 21, 2017 6:08:54 AM(UTC)
dark_ata
Was thanked: 18 time(s) in 13 post(s)
on paper BM DeckLink 4K Extreme 12G, and DeckLink 4K Pro + Teranex Mini HDMI to SDI 12G. but at the moment we dont have any 12G decklink to check
droza
#3 Posted : Saturday, October 28, 2017 2:55:41 AM(UTC)
droza
I asked vMix to test the Magewell card about this here: https://forums.vmix.com/default.aspx?g=posts&t=11963. Hopefully they can get around to it at some point.
thanks 1 user thanked droza for this useful post.
RandomStreamer on 11/7/2017(UTC)
zenvideo
#4 Posted : Saturday, October 28, 2017 6:36:44 AM(UTC)
zenvideo
The Magewell Pro Capture HDMI 4K Plus supports the HDMI v2.0 signal standard, which includes 4K60p (obviously), but not every single permutation of colour sampling (4:2:2, 4:2:0, etc) and bit depth (8-bit, 10-bit, etc). I have used it with vMix, and done tests to check it's OK at 4K60p with the output from a graphics card (because I don't have a 4K60p camera).
RandomStreamer
#5 Posted : Tuesday, November 7, 2017 5:37:25 PM(UTC)
RandomStreamer
I had come to the same conclusion... also the magewell 4k60..
End of the day just feels risky to try it "blind"
Gonna stick with the 4k30 mini recorder until a decent solution is proven.
