pasingshot
#1 Posted : Thursday, October 12, 2017 4:23:19 AM(UTC)
pasingshot
Hi guys, is it normal that the use of cpu with the web browser is 20-25% for each entry that opens? Need to configure something?
My PC components:
Win 10
Vmix 17
Intel i5 3ghz
8Gb Ram
Nvidia GTX960 4GB
1TB Hdd
Thanks in advance
mjgraves
#2 Posted : Thursday, October 12, 2017 6:49:21 PM(UTC)
mjgraves
That seems high, but may not be outta line. It will depend upon what you load into the browser. On my system playing a YouTube video in 720p in full screen in a 720p30 project runs 17-18% of CPU.
i7-5775C Quad Core 3.0 GHz
Windows 10
16 GB RAM
GTX750 2GB
512 GB SSD
pasingshot on 10/14/2017(UTC)
Torreanurban
#3 Posted : Friday, October 20, 2017 12:45:41 PM(UTC)
Torreanurban
I am just trying to find out. I am testing this software before I buy to see if it will work for me. So far love the program however, when I add webpages for layouts I use in my stream for gaming my CPU usage goes super high almost always 100% and I am just using the machine to stream. What I am wondering, is there a way when the webpages aren't in use they can stop refreshing as I think that is the problem they are always updating. If I remove em the cpu % drops a lot. Again just testing to see if I stay with what I got or buy this.
sinc747
#4 Posted : Friday, October 20, 2017 1:26:59 PM(UTC)
sinc747
Was thanked: 204 time(s) in 170 post(s)
Check your PC specs against the vMix recommendations here. You may be under spec.
- Tom
