Thanks: 32 times Was thanked: 2 time(s) in 2 post(s)
Hi guys, is it normal that the use of cpu with the web browser is 20-25% for each entry that opens? Need to configure something?
My PC components:
Win 10 Vmix 17 Intel i5 3ghz 8Gb Ram Nvidia GTX960 4GB 1TB Hdd
Thanks in advance
That seems high, but may not be outta line. It will depend upon what you load into the browser. On my system playing a YouTube video in 720p in full screen in a 720p30 project runs 17-18% of CPU.
i7-5775C Quad Core 3.0 GHz Windows 10 16 GB RAM GTX750 2GB 512 GB SSD
I am just trying to find out. I am testing this software before I buy to see if it will work for me. So far love the program however, when I add webpages for layouts I use in my stream for gaming my CPU usage goes super high almost always 100% and I am just using the machine to stream. What I am wondering, is there a way when the webpages aren't in use they can stop refreshing as I think that is the problem they are always updating. If I remove em the cpu % drops a lot. Again just testing to see if I stay with what I got or buy this.
Torreanurban wrote:I am just trying to find out. I am testing this software before I buy to see if it will work for me. So far love the program however, when I add webpages for layouts I use in my stream for gaming my CPU usage goes super high almost always 100% and I am just using the machine to stream. What I am wondering, is there a way when the webpages aren't in use they can stop refreshing as I think that is the problem they are always updating. If I remove em the cpu % drops a lot. Again just testing to see if I stay with what I got or buy this. Check your PC specs against the vMix recommendations here. You may be under spec. - Tom
