Joined: 7/1/2016(UTC) Posts: 48  Location: Italy Thanks: 5 times Was thanked: 4 time(s) in 4 post(s)
maybe someone can give me a tip from you how I can best implement this requirement? For a castingshow we have to make the graphics for the voting results. There should be 10 beams, which must have a different length depending on the percentage of the result. The bars should build from the left, first the last, shortest beam, then the second from below with the corresponding percentage. When all the bars are shown, the names of the participants, one after the other, should be displayed on the corresponding bar.
Is something possible, possibly with UTC? If so how, or is there a special software for this?
Thx
ps where would the data be comming from ?
Joined: 1/22/2020(UTC) Posts: 47  Location: Montpellier Thanks: 14 times Was thanked: 2 time(s) in 2 post(s)
Originally Posted by: doggy  if you are looking into creating it yourself as a xaml title for vmix google "xaml progressbar" as a basis.
Hi Doggy ! (I wanted to reply on this topic as it is closer to my new question) I'm using those progress bars for my project (For people passing by : Lots of infos here : https://forums.vmix.com/...-Titolo-Grafico-a-Barre)and here is my issue :  Red : ProgressBar Blue : Rectangle There is this white transparent overlay on the progressbar and it's annoying me, do you know if there is a way to get rid of it ? Here on Blend we can see there is no gradient overlay :  This example is on NET 3.5. It's the same problem with 4+
I believe thats the standard for a progressbar . possible changeable with some styling
I feel like it is VMIX's interpretation of the progression bar style, which takes over my style.. Is there any guide going deep in how VMIX takes all of that ? Maybe a developper kit I missed or something ?
Originally Posted by: davidcallahan  I feel like it is VMIX's interpretation of the progression bar style, which takes over my style.. Is there any guide going deep in how VMIX takes all of that ? Maybe a developper kit I missed or something ? If you do something similar in a regular windows xaml application you will get the same result. Also i dont see any styling in the code
Originally Posted by: doggy  Also i dont see any styling in the code
Isn't this : the style of my progressbar? I've changed every progress bar into rectangles and it works fine thought. But I'd like to understand what went wrong
