ben1000
#1 Posted : Thursday, October 5, 2017 8:49:44 AM(UTC)
ben1000
Howdy...
I'm new to vMix, but have a long streaming history...
I'm running the system on an i7 quad core system with BM input cards, and everything is working just great... When recording (not streaming) to H.264 with hardware encoding, my system reports just 10% load, which is wonderful...
However, I notice that around once every hour or so, I get a 1s glitch on the video, where the audio continues without a problem, but the video glitches and jumps, and ends up 1s out of sync...
Not the worst problem to fix in post, but still a bit of a pain...
This is not apparent on the screen.... The lip sync is dead on all the way to the end when I stop recording... But when I check the recording on my MAC afterwards... the beginning is great, but somewhere during the hour, there will be this glitch, and the video jumps out of sync with the audio...
Once I fix that, all is good... I haven't seen this happen more than once per hour (each of my recordings is around an hour) but I'm not sure what's causing it...
I've run Wirecast and Livestream Studio on this PC without experiencing this issue, although not recording to H.264... I really like the H.264 recording on the system, so I'd love to get this working...
Can you shed any light?
Thanks!
Best,
Ben
Benjamin Freedman
PrimeImage Media
stevespaw
#2 Posted : Thursday, October 5, 2017 11:06:32 AM(UTC)
stevespaw
Was thanked: 75 time(s) in 57 post(s)
What Motherboard?
Steve
ben1000
#3 Posted : Thursday, October 5, 2017 11:23:01 AM(UTC)
ben1000
Hmmm... I'm not sure. I believe it's a Gigabyte, but I don't have it in front of me...
Best,
Ben
stevespaw
#4 Posted : Thursday, October 5, 2017 12:45:25 PM(UTC)
stevespaw
We have these type of issues on x99 Motherboards.
Steve
ben1000
#5 Posted : Thursday, October 5, 2017 1:33:33 PM(UTC)
ben1000
I see... Well this computer is a couple of years old, so I don't think it's an X99...
It's very strange.. Works really well for 99% of the time, then just 1s of 'glitch' every hour or so... Really hope I can find out the issue....
Best,
Ben
kjones9999
#6 Posted : Thursday, October 5, 2017 8:29:00 PM(UTC)
kjones9999
What are your recording specs?
ben1000
#7 Posted : Friday, October 6, 2017 2:08:45 AM(UTC)
ben1000
Howdy...
20mbps H.264.... Hardware encoding. Everything else default.
Recording to an external USB3.0 SSD
Best,
Ben
ben1000
#8 Posted : Saturday, October 7, 2017 8:32:26 PM(UTC)
ben1000
Howdy...
So, quick update... This seems to happen about once an hour but not specifically exactly every hour... It's easy to fix in post as the glitch is always almost exactly 30 frames or 1s long... Also, it doesn't seem to matter what input is selected at the time... Whether one of my 2 cameras or the input from an HDMI computer via a Decimator...
Would love to hear if anyone knows a solution I could try...
Best,
Ben
sinc747
#9 Posted : Sunday, October 8, 2017 5:47:27 PM(UTC)
sinc747
Was thanked: 201 time(s) in 167 post(s)
Can you monitor your system and see what the CPU use is when the glitch occurs?
There may be another application on your PC that is operating occasionally. Task Manager will show you what it is, but only in real time. So, you could set up a test that included the Task Manger window as part of your recording so you could see what app is spiking at that moment.
- Tom
#10 Posted : Sunday, October 8, 2017 7:29:59 PM(UTC)
Was thanked: 795 time(s) in 589 post(s)
I see 2 possible reasons:
- USB external drive : does this happen when using an internal disk on Sata ? > hardware issue
- Did you try recording with FFMPEG (not the default MP4 recording mode) ? > software issue
It could be interesting to try this in order to find where to search for the exact cause.
Guillaume
ben1000
#11 Posted : Sunday, October 8, 2017 9:26:08 PM(UTC)
ben1000
Howdy...
Good suggestions...
I plan on doing a test tomorrow for a couple of hours.. I'll bring in the desktop as an input and run Task Manager on it...
I'll also use an internal drive, although I doubt that's the issue... Recording at 20mbps, there shouldn't be any drive that can't keep up :)
Will let you know how that goes.
Best,
Ben
sinc747
#12 Posted : Sunday, October 8, 2017 9:51:06 PM(UTC)
sinc747
Also disable any virus protection you may be using.
- Tom
