Rewire_getz
#1 Posted : Tuesday, October 3, 2017 10:40:07 AM(UTC)
Rewire_getz
Hello.
Colleagues when I start stream's after a few seconds i saw error in log file, and stream's stop.
av_interleaved_write_frame(): Unknown error
[flv @ 00a85520] Failed to update header with correct duration.
[flv @ 00a85520] Failed to update header with correct filesize.
[flv @ 00ab3ec0] Failed to update header with correct duration.
[flv @ 00ab3ec0] Failed to update header with correct filesize.
[flv @ 00ad2380] Failed to update header with correct duration.
[flv @ 00ad2380] Failed to update header with correct filesize.
frame= 14 fps=0.0 q=-1.0 Lq=-1.0 q=28.0 size= 69kB time=00:00:00.61 bitrate= 913.0kbits/s
video:157kB audio:1kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
What is the reason for this ?
P.S.
Vmix 20.0.0.30
Win 7
kjones9999
#2 Posted : Wednesday, October 4, 2017 8:42:14 PM(UTC)
kjones9999
It would seem something is mismatched. Where are you trying to stream, what are the settings, and are you trying to do anything at 14 FPS?
#3 Posted : Wednesday, October 4, 2017 10:01:35 PM(UTC)
https://www.vmix.com/kno...ng-ffmpeg-streaming-logs
av_interleaved_write_frame(): Input/output error
This error means the stream has disconnected which can occur for one of the following reasons:
1. Local internet outage
2. Streaming provider internet outage
3. Streaming provider has closed the stream for some reason
yakkatv
#4 Posted : Saturday, June 11, 2022 11:56:59 PM(UTC)
yakkatv
Lithuania
have same issue with customs rtmp source run good we could not stream
