Joined: 10/3/2017(UTC) Posts: 1 Location: Moscow, Russia
Hello.
Colleagues when I start stream's after a few seconds i saw error in log file, and stream's stop.
av_interleaved_write_frame(): Unknown error [flv @ 00a85520] Failed to update header with correct duration. [flv @ 00a85520] Failed to update header with correct filesize. [flv @ 00ab3ec0] Failed to update header with correct duration. [flv @ 00ab3ec0] Failed to update header with correct filesize. [flv @ 00ad2380] Failed to update header with correct duration. [flv @ 00ad2380] Failed to update header with correct filesize. frame= 14 fps=0.0 q=-1.0 Lq=-1.0 q=28.0 size= 69kB time=00:00:00.61 bitrate= 913.0kbits/s video:157kB audio:1kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
What is the reason for this ?
P.S.
Vmix 20.0.0.30 Win 7
It would seem something is mismatched. Where are you trying to stream, what are the settings, and are you trying to do anything at 14 FPS?
Joined: 1/13/2010(UTC) Posts: 5,370  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
https://www.vmix.com/kno...ng-ffmpeg-streaming-logsav_interleaved_write_frame(): Unknown error av_interleaved_write_frame(): Input/output error This error means the stream has disconnected which can occur for one of the following reasons: 1. Local internet outage 2. Streaming provider internet outage 3. Streaming provider has closed the stream for some reason
have same issue with customs rtmp source run good we could not stream
