Matou
#1 Posted : Sunday, September 24, 2017 2:47:28 AM(UTC)
Matou
Italy
I have windows 10 and Vmix 20 and so far I have not had any particular crashes. However, there is an audio problem when embed (web browser) video from Youtube: there is no audio. I used the "default windows playback device" configuration. Does it happen to you too? Do I have to put some command string to "enable" the audio? With Windows 8.1 and Vmix 19 I did not have this problem.
Thanks for your help.
Ciao,
ho windows 10 e Vmix 20 e sinora non ho avuto particolari crash. Sorge però un problema di audio quando embed (web Browser) il video da Youtube: non c'è audio. Ho usato la la configurazione "default windows playback device" . Succede anche a Voi? Devo mettere qualche stringa di comando per "abilitare" l'audio? Con Windows 8.1 e Vmix 19 non avevo questo problema.
Grazie per l'aiuto.
Alan - Matou.tv
#2 Posted : Sunday, September 24, 2017 5:25:41 AM(UTC)
Hi Alan
I just checked playing a YT video in a WebBrowser input: it works perfectly with audio.
Check if your audio options & routing is correct. The issue is definitely on your side.
Guillaume
Matou on 9/24/2017(UTC)
Matou
#3 Posted : Sunday, September 24, 2017 8:48:12 AM(UTC)
Matou
Italy
Hi, Guillaume you confirm to have Windows 10 and Vmix 20? I have 2 computers one with windows 8.1 and Vmix 19 and it works perfectly. The video clips feel perfectly, I updated for scrupulous Adobe Flash player, I have two audio settings with realteck so i have no other possibilities. Audio works but not with the Web, will I be the only one to have this problem?
Thank you!
Ciao, Guillaume, vous confirmez avoir Windows 10 et Vmix 20? J'ai 2 ordinateurs un avec Windows 8.1 et Vmix 19 et ça fonctionne parfaitement. Les clips vidéo se sentent parfaitement, j'ai mis à jour pour scrupuleux Adobe Flash Player, j'ai deux paramètres audio avec realteck, donc je n'ai pas d'autres possibilités. L'audio fonctionne mais pas avec le Web, est-ce que je serai le seul à avoir ce problème?
Merci!
#4 Posted : Sunday, September 24, 2017 9:05:46 AM(UTC)
Yes I tested with Windows 10 Pro 64 bits and vMix Pro 20.0.0.27.
FYI I believe vMix does not rely on Flash player for WebBrowser Input, as it is a Chromium embedded in vMix and I think it uses native HTML5 player from YT.
To make sure, just try another video from another OVP like vimeo for example or simply accessing a web radio via the WebBrowser input.
Another option is to use the RTMP input to play this YT video.
Mi dispiace che il mio italiano non sia abbastanza buono da rispondere. Congratulazioni per il vostro francese, è molto buono.
Cordiali saluti
Guillaume
Matou
#5 Posted : Sunday, September 24, 2017 9:55:34 AM(UTC)
Matou
Italy
Hi, Guillaume for the directions. Any web input: YT, radio, vimeo - vmix vumeter does not give any signs of life. You can kindly point me to the RTMP syntax (for example, I must embed this video: https://www.youtube.com/embed/Su6CJ55cXgA). I am an ultra-fifty-year-old newbie, so be patient!
Thanks again.
Merci, Guillaume pour les indications. Toutes les entrée Web: YT, radio, vimeo - les vu meters de Vmix ne donnes aucun signe de vie. Une gentillesse: vous pouvez m'indiquer la syntaxe RTMP (par exemple, je dois intégrer cette vidéo: https://www.youtube.com/embed/Su6CJ55cXgA).
Je suis un newbie de plus de cinquante ans, alors soyez patient ;-) !
Merci encore.
#6 Posted : Sunday, September 24, 2017 10:21:33 AM(UTC)
OK I thought so, the audio is not related to YT or the WebBrowser input in vMix.
It's certainly that you forgot to click the M icon for this input audio or you're doing something wrong with audio routing on buses A & B.
Make sure to read the documentation for audio use and settings here : https://www.vmix.com/help20/Audio3.html
Or simply check you're doing the same as on Win8/vMix19 on this Win10/vMix20 computer...
You can PLAY any video from YouTube in vMix using the Flash/RTMP input type with this syntax :
http://www.youtube.com/v/VIDEO_ID
(for example http://www.youtube.com/v/4IhWsOqCWpc)
Guillaume (btw I'm 50 too!)
Matou
#7 Posted : Saturday, September 30, 2017 8:21:23 AM(UTC)
Matou
Italy
Hi, unfortunately I tried all possible audio configurations (I think). Is there anyone who has an Asus Notebook with Windows 10, where does audio with embeded web clips work?
Asus says it's not a problem for them, Windows says it's an Asus problem ........
Every help is appreciated!
Thank you
Matou
#8 Posted : Saturday, October 7, 2017 2:05:13 PM(UTC)
Matou
Italy
Solved!
Thanks to your directions, I focused the problem.
So, first I disable the drivers (windows 10 and asus do not allow you to uninstall the drivers!).
There is an Asus application called Sonic Suite 2, I have disabled this application at startup as well. I have reinstalled the drivers manually and finally everything works !!!
Thank you very much !
Thanks Martin for the time you've dedicated me!
in Italian:
Risolto! Grazie Martin alle tue indicazioni, ho focalizzato il problema.
Allora, per prima cosa ho disabilitato i driver ( windows 10 e asus non permettono di disinstallare i drivers!) .
C'è una applicazione di Asus che si chiama Sonic suite 2, ho disabilitato all'avvio anche questa applicazione.
Ho reinstallato i drivers manualmente e finalmente tutto funziona!!! Grazie veramente !
Grazie per tutto il tempo che mi hai dedicato!
#9 Posted : Sunday, October 8, 2017 6:54:08 AM(UTC)
@ Matou
Glad you got it solved!
I am curious though about which drivers you actually had to remove and reinstall?
Matou
#10 Posted : Sunday, October 8, 2017 7:50:06 AM(UTC)
Matou
Italy
Hi, thanks to Martin's lines, which let me know where to go, I went to read Microsoft's instructions on how to uninstall - here:
https://answers.microsof...6-e011-8dfc-68b599b31bf5
I then went to the official site of Asus and downloaded the latest audio release.
Ciaoooo ;-)
aldoyh
#11 Posted : Saturday, November 11, 2017 7:06:13 AM(UTC)
aldoyh
Hello, Thanks everyone for the help, but I'm still unable to achieve that!
Using this embed code https://www.youtube.com/embed/8IQbF0IK-f4
Didn't show anything,
But using this one https://www.youtube.com/v/8IQbF0IK-f4
Showed the attached.
[img]https://ibb.co/nrXKfw[/img]
Using the simple Web Browser as YouTube input resulted in No Audio given (checked audio driver very well)
Please help!
aldoyh attached the following image(s):
vMix Capture 10 November 2017 02-50-26.png (1,197kb) downloaded 6 time(s).
#12 Posted : Saturday, November 11, 2017 8:13:07 AM(UTC)
is what i noticed too recently, impossible to get YT videos or streams to play in vMix directly anymore
NHT
#13 Posted : Saturday, November 11, 2017 1:01:48 PM(UTC)
NHT
Hi Alan, I have nothing technical to add except you are a lucky person, I spent a few weeks working in the Aosta Valley and it's beautiful.
thanks 1 user thanked NHT for this useful post.
Matou on 11/11/2017(UTC)
Mari
#14 Posted : Saturday, November 11, 2017 2:11:13 PM(UTC)
Mari
Netherlands
No problems at all... open both links in vMix and when playing there is audio!
Matou
#15 Posted : Saturday, November 11, 2017 3:22:12 PM(UTC)
Matou
Italy
Hi, even to me it "seemed" that audio drivers were installed. Truly the update does not happen! Try not to cost anything, follow the microsoft instructions to uninstall audio drivers and install the latest version of your sound card. I've tried, now Vmix's Web Browser and it works. Let me know! Ciao
Ciao, anche a me "sembrava" che i drivers audio si siano stati installati. Però l'aggiornamento non avviene! Provare non costa nulla, seguite le istruzioni microsoft per disinstallare i driver audio e installare la versione più recente della Vostra scheda audio. Io ho provato ora, il browser web di Vmix e funziona. Fatemi sapere! Ciao
Matou attached the following image(s):
