amsudeen
#1 Posted : Wednesday, May 15, 2013 3:49:50 AM(UTC)
amsudeen
Was thanked: 8 time(s) in 6 post(s)
LOOP PLAY LAST FRAME DELAY.
SINGLE QTA FILE LOOP ONE FRAME DELAY & JUMP.
CHECK MY VIDEO :
#2 Posted : Wednesday, May 15, 2013 4:27:01 AM(UTC)
Was thanked: 4664 time(s) in 1607 post(s)
I have moved this to a separate thread.
Could you please upload the quicktime file so I can test?
What you are looking for is called "Seamless looping" which is not supported by QuickTime itself.
vMix does its best to loop as fast as possible, but some video formats work better than others.
amsudeen
#3 Posted : Wednesday, May 15, 2013 5:22:00 AM(UTC)
amsudeen
single QTA FILE EACH PLAY ( LOOP ) JUMP.
SINGLE AVI FILE LOOP PLAY VERY SMOOTHLY.
EVERY PLAY GO TO PAUSE AND THEN PLAY. SO, IT WAS JUMP.
TeODH4
#4 Posted : Wednesday, May 15, 2013 8:01:20 AM(UTC)
TeODH4
Martin wants you to upload the physical quicktime file you used for the loop. So he can test it for you. You can use a file sharing service such as http://mediafire.com for this.
Best Regards,
Wayne Hartmann
amsudeen
#5 Posted : Wednesday, May 15, 2013 12:28:31 PM(UTC)
amsudeen
TeODH4
#6 Posted : Thursday, May 16, 2013 12:07:45 AM(UTC)
TeODH4
Indeed there does seem to be a looping issue with MOV's Martin. However there are also issues with the loop files themselves as well. Please see my video here
I'll show you a fix you can use in the mean time until this gets sorted.
Best Regards,
Wayne Hartmann
#7 Posted : Thursday, May 16, 2013 12:30:47 AM(UTC)
This is actually a limitation of QuickTime itself as when the "StartMovie" command is sent to QuickTime
it doesn't actually start playback for a couple of frames.
For small animations, the best option for seamless looping is to export the video as an "Image Sequence" which most video editors support.
If that is not possible then the next best format is an AVI encoded using a codec such as MJPEG.
TeODH4
#8 Posted : Thursday, May 16, 2013 1:00:50 AM(UTC)
TeODH4
Thanks for the insight Martin.
Best Regards,
Wayne Hartmann
amsudeen
#9 Posted : Saturday, May 25, 2013 11:06:41 AM(UTC)
amsudeen
hi,
quick time file it was with alpha. other format avi, mp4 not support alpha.
the same time, image sequence not load more then one.
VMIX error
D3DERR OUT OF VIDEO MEMORY. -2005532292.
macjaeger
#10 Posted : Saturday, May 25, 2013 12:43:53 PM(UTC)
macjaeger
Sounds to me like a physical limitation of your hardware. What graphics card / chipset are you using?
amsudeen
#11 Posted : Saturday, May 25, 2013 9:39:25 PM(UTC)
amsudeen
ASUS P8H77-V LE
INTEL I7 3770
16 GB RAM DDR3
NVIDIA GT-640 2GB
macjaeger
#12 Posted : Sunday, May 26, 2013 4:18:18 AM(UTC)
macjaeger
Nay, that gfx card should be well suited for your needs; so this error comes from elsewhere.
#13 Posted : Sunday, May 26, 2013 5:54:17 AM(UTC)
The error will occur under the 32bit version of vMix and the image sequence is more than around 100 HD frames.
Try the 64bit version of vMix which has access to far more memory.
amsudeen
#14 Posted : Monday, May 27, 2013 9:36:25 PM(UTC)
amsudeen
hi
vmix 64-bit not support quicktime file. we are using quicktime files and png sqsequence files.
sqsequence files cann't do list option.
please give me solution. work well quick time files and png sqsequence.
#15 Posted : Monday, May 27, 2013 10:26:26 PM(UTC)
Image Sequence is intended to replace any quicktime loop files you have.
Any other videos should be converted from quicktime to another format such as MP4.
These are limitations of QuickTime so there isn't much I can do about it.
amsudeen
#16 Posted : Tuesday, May 28, 2013 1:22:18 AM(UTC)
amsudeen
i purchase via re seller program. i want develope more effects in vmix. and sale vimix and support indian wedding video grapher.
actually, we are support wedding videogaphers.
develop any effect related with alpha. but, MP4 not support alpha ?
plase, give me any idea with aplha include list.
thanku
#17 Posted : Tuesday, May 28, 2013 2:42:48 AM(UTC)
As previously mentioned, to use alpha I recommend the 64bit version of vMix with image sequences.
