vMix Call
Changing vMixCall Output Issue...
Joined: 5/27/2017(UTC) Posts: 93   Location: Greater St Louis Area Thanks: 67 times Was thanked: 20 time(s) in 13 post(s)
I've done this twice today with the same result: I begin a vMixCall session with multiple parties. In vMix, I went to CHANGE the OUTPUT sent to one party (me, for the initial test) and instead of switching from Output 1 (the stream) to Output 2 (multiview), it garbled the output sent to me (in the call session).
I then had the brilliant idea to try the same with a client, and it did the same. No real damage was done, but better to function correctly.
Is this a known bug, or am I the first, or am I alone and this is not a bug but I've misunderstood how to use the tool?
Thank you,
Chad
Joined: 1/13/2010(UTC) Posts: 5,367  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
Hi Chad,
We haven't seen this issue, but can you confirm you are running vMix 20? There have been a number of improvements in regards to the output switching in call in 20, and I just ran a test now to confirm I could switch the output channel and/or source of a channel cleanly on the guest preview in Chrome.
Martin vMix
Correction: I can switch once, then subsequent changes are garbled. I am running version 20.0.0.27. Here's an image sequence so you can see what I see (attached). Hope this helps! Chad clafarge attached the following image(s):  vMC1.jpg (110kb) downloaded 3 time(s). vMC2.jpg (105kb) downloaded 4 time(s). vMC3.jpg (139kb) downloaded 3 time(s).You cannot view/download attachments. Try to login or register.
vMix Call
