clafarge
#1 Posted : Wednesday, September 20, 2017 11:49:26 AM(UTC)
clafarge
Was thanked: 20 time(s) in 13 post(s)
I've done this twice today with the same result: I begin a vMixCall session with multiple parties. In vMix, I went to CHANGE the OUTPUT sent to one party (me, for the initial test) and instead of switching from Output 1 (the stream) to Output 2 (multiview), it garbled the output sent to me (in the call session).
I then had the brilliant idea to try the same with a client, and it did the same. No real damage was done, but better to function correctly.
Is this a known bug, or am I the first, or am I alone and this is not a bug but I've misunderstood how to use the tool?
Thank you,
Chad
#2 Posted : Wednesday, September 20, 2017 12:31:13 PM(UTC)
Was thanked: 4710 time(s) in 1614 post(s)
Hi Chad,
We haven't seen this issue, but can you confirm you are running vMix 20?
There have been a number of improvements in regards to the output switching in call in 20, and I just ran a test now to confirm
I could switch the output channel and/or source of a channel cleanly on the guest preview in Chrome.
clafarge
#3 Posted : Wednesday, September 20, 2017 1:24:07 PM(UTC)
clafarge
Correction: I can switch once, then subsequent changes are garbled.
I am running version 20.0.0.27.
Here's an image sequence so you can see what I see (attached).
Hope this helps!
Chad
clafarge attached the following image(s):
