4 Pages<1234>
Murchik
#41 Posted : Sunday, September 17, 2017 4:05:37 PM(UTC)
Murchik
Ukraine
this is good, but when it will be possible to stream 2 different outputs, for example master and external 2?
Ezekiel3vs18
#42 Posted : Sunday, September 17, 2017 4:47:37 PM(UTC)
Ezekiel3vs18
Curt M wrote:
Output Streaming quality #1 is locked in H.264 1920x1080 1080p, with no access to the sprocket to change this function. I can set the stream quality for destinations 2 and 3 (or select to use same as #1) fine.
Some of my work has to be done at 720p for two outputs due to bandwidth up at location. I can use 2 & 3 and go to "None" on #1. but then it elminates my ability to use 3 streams if I'd like to, unless I have more bandwidth
I've looked in the big Setting page, and this condition of quality setting does not change, even with changes to display options.
Am I missing something?
Thanks in advance
Yes, I had the same issue. I resolved the problem by rebuilding the Stream Profile.
#43 Posted : Monday, September 18, 2017 1:52:06 AM(UTC)
If anyone is seeing the Stream #1 quality greyed out can you go to Settings -> About and click Send Support Report
and drop us an email at info@vmix.com.au so we can resolve it.
Thanks,
Curt M
#44 Posted : Monday, September 18, 2017 4:18:27 PM(UTC)
Curt M
Thanks in advance
Ok. I'll bite: How do you do that?
I'm sure it's not as simple as just changing to another streaming location. I just tried to shift it to YouTube Live and then back. Both settings still grey.
Thanks in advance for the fix specifics!
Curt M
#45 Posted : Monday, September 18, 2017 6:00:52 PM(UTC)
Curt M
Thanks in advance
I pulled up the stream page, left it on #1, then did "delete."
Once I did that, the sprocket lit up and the line to the left wasn't greyed anymore, and then you can get to the frame to configure your settings.
Easy enough to work around!
Thanks for the general directions that got me there!
#46 Posted : Friday, September 22, 2017 11:33:53 PM(UTC)
I've been informed the lower cost options of NewBlue Titler Live will be available to purchase in a couple of weeks time starting from around
$450 USD. Broadcast was released first.
thanks 5 users thanked admin for this useful post.
BETech on 9/22/2017(UTC), ask on 9/23/2017(UTC), sinc747 on 9/23/2017(UTC), madness on 9/23/2017(UTC), ON.tv Channels on 9/26/2017(UTC)
Arth
#47 Posted : Tuesday, September 26, 2017 9:50:42 AM(UTC)
Arth
I have some NDI sources with 8 audio channels but I need only the 2 first ones. So, I use the newly added Channel Matrix under Input > General > Audio Settings to select the first channel as L and the second as R for all bus. But when saving the configuration, closing vMix and reopening the saved configuration, these parameters are forgotten and the Channel Matrix went back to its defaults. Is there a way to include this in the saved configuration?
#48 Posted : Tuesday, September 26, 2017 10:21:35 AM(UTC)
Thanks for reporting this, there appears to be a bug where 6 and 8 channels are reset to default.
This will be fixed in the next update.
ON.tv Channels on 9/26/2017(UTC), Arth on 10/7/2017(UTC)
Murchik
#49 Posted : Tuesday, October 10, 2017 7:46:00 PM(UTC)
Murchik
Ukraine
After updating after recording more than 2 hours gives an error
The name of the failed application: vMix64.exe, version: 20.0.0.30, time stamp: 0x59cc70e1
The name of the failed module: mscorwks.dll, version: 2.0.50727.8745, time stamp: 0x573d296c
Exception code: 0xc0000005
adagra
#50 Posted : Monday, October 16, 2017 11:12:39 AM(UTC)
adagra
I still have the same problems in this version of vMix:
Event filter with query "SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA" Win32_Processor "AND TargetInstance.LoadPercentage> 99" could not be reactivated in namespace "//./root/CIMV2" because of error 0x80041003. Events can not be delivered through this filter until the problem is corrected.
.NET Runtime version 2.0.50727.8762 - Critical Runtime Error (000007FEF340104E) (80131506)
Name of application causing the error: VMIX64.EXE, version: 20.0.0.30, timestamp: 0x59cc70e1
Name of module causing the error: mscorwks.dll, version: 2.0.50727.8762, timestamp: 0x58e462f0
Error offset: 0x000000000055bd8b
Process ID causing the error: 0x%9
Runtime error: 0x%10
Application path causing error: %11
Path of error causing module: %12
Report ID: %13
- System
  - Provider
   [Name] Application Error
  - EventID 1000
   [Qualifiers] 0
   Level 2
   Task 100
   Keywords 0x80000000000000
  - TimeCreated
   [SystemTime] 2017-10-15T13: 33: 11.000000000Z
   EventRecordID 73372
   Channel Application
   Computer AMD-EMISJA
   Security
- EventData
   VMIX64.EXE
   20.0.0.30
   59cc70e1
   mscorwks.dll
   2.0.50727.8762
   58e462f0
   c0000005
   000000000055bd8b
I translate it in Google Translator, because I have Windows7 Pro in Polish language version.
These problems every three hours completely shut down vMix and stop my transmission.
Please for help about it and very sorry for my English.
Regards for All,
adam
#51 Posted : Wednesday, October 18, 2017 1:22:01 AM(UTC)
Please drop us an email at info@vmix.com.au regarding the error after recording so we can investigate further.
We have been recording for many hours without issue, so it may be particular to the recording format used, or maybe a bug in a driver or codec.
prass
#52 Posted : Thursday, November 2, 2017 7:16:06 AM(UTC)
prass
Was thanked: 3 time(s) in 1 post(s)
Hello!
First I'm sorry for my bad English.
When display 2 is on and function ''On top'' is on, all dropdown menus is not there that supposed to be.
Configuration:
4 Monitors (2 TV, 2 Monitors)
Videocard: Nvidia Geforce GTX 980 Gygabute G1 Gaming 4GB or EVGA GeForce GTX 970 SC GAMING ACX 2.0 4GB
Procesor: Intel i7 5820K 3.30 GHz overclocked to 4.2 Ghz with liquid cooling
RAM: Hyper X Savage DDR 4 2x8GB
Power Suplay: FSP 650W
Windows 10
Best regards,
Gplay TV
File Attachment(s):
Screenshot 1.png (2,723kb) downloaded 28 time(s).
Screenshot 2.png (3,069kb) downloaded 19 time(s).
Screenshot 3.png (3,146kb) downloaded 20 time(s).
Screenshot 5.png (3,138kb) downloaded 12 time(s).
prass attached the following image(s):
Screenshot 4.png (2,383kb) downloaded 6 time(s).
Rinsky
#53 Posted : Saturday, November 25, 2017 9:48:12 AM(UTC)
Rinsky
It says "* Basic support for photos added to List input" in the changelog, so I put some photos (.jpg and .png) together with some videos in a list, but it skipped the photos very fast. I think it also worked like this before the update.
Is there going to be a way to set the time a photo is shown? And maybe even add transitions between the items? Actually it would be great to have the option to add basically any input to the list, even XAML files to show some social media posts or stats within the list.
Patrick
Update: I just updated to version 20.0.0.42 and it seems that the skip through only occurs on PNG files. JPGs are shown for about 10 seconds.
#54 Posted : Saturday, December 2, 2017 11:13:08 AM(UTC)
Hi!
maybe a slight problem with 20.0.0.44 and VST3? Maybe you can reproduce the same error?
When closing vMix with several plugins windows opened, vMix display an error message and fails to stop nicely.
When all plugin windows are closed BEFORE closing vMix, it's fine.
Not a big deal but I got this 3 times in 2 days.
Bien à vous,
Guillaume
prass on 12/19/2017(UTC)
#55 Posted : Saturday, December 2, 2017 11:25:43 AM(UTC)
I'm not seeing this with some quick tests, but I guess it depends on the type of plugins being loaded.
Maybe a certain combination of plugin brands is more prone to the error.
dark_ata
#56 Posted : Wednesday, January 3, 2018 8:13:19 AM(UTC)
dark_ata
Was thanked: 18 time(s) in 13 post(s)
Yesterday the vmix crash while we uses it as mixer for TV, and also see some stranger thing in the proyect, in one of the dual screen was impossible put the source 6, the background was put in loop, disable the auto start restart or pause, and stoped the video, and when change some source one video that uses for try start playing alone...
Code:
- System
  - Provider
   [ Name]  Windows Error Reporting
  - EventID 1001
   [ Qualifiers]  0
   Level 4
   Task 0
  - TimeCreated
   [ SystemTime]  2018-01-01T00:22:55.940421300Z
   EventRecordID 10153
   Channel Application
   Computer DESKTOP-U5JOS5D
   Security
- EventData
   0
   CLR20r3
   No disponible
   0
   vmix64.exe
   20.0.0.46
   5a293c11
   mscorlib
   2.0.0.0
   59a72025
   1a4b
   0
   System.StackOverflowException
   C:\ProgramData\Microsoft\Windows\WER\ReportQueue\AppCrash_vmix64.exe_8619b78a18a9e5e1478332cb72415cb77d3fbb4d_00000000_077d4569
   0
   1fa468d5-d666-4dc5-97ff-3954ee712cf8
   6
dark_ata
#57 Posted : Wednesday, January 3, 2018 9:30:10 AM(UTC)
dark_ata
CRITICAL BUG
with the multiview of a source (1) disabled and with that source (1) loaded in a multiview (2) if by mistake you put in the source (1) with the multiview disabled the source (2) closes. I know it's a loop, but it can happen.
i think that if the multiview in one source is disable this not could charge/play anything this was all the stranger thing that i see in the post. but the crash report not is the same when crash for the loop of sources the report is
Code:
- System
  - Provider
  - EventID 1001
   [ Qualifiers]  0
   Level 4
   Task 0
  - TimeCreated
   [ SystemTime]  2018-01-02T13:12:02.928617000Z
   EventRecordID 10297
   Channel Application
   Security
- EventData
   2170698156674616861
   4
   APPCRASH
   No disponible
   0
   vMix64.exe
   20.0.0.46
   5a293c11
   KERNELBASE.dll
   6.2.16299.15
   4736733c
   e053534f
   0000000000013fb8
   \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERB947.tmp.mdmp \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERC109.tmp.WERInternalMetadata.xml \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERC116.tmp.csv \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERC127.tmp.txt
   C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_vMix64.exe_94ce7f5f0d848444ffd224738bac415f7c78218_00000000_6f0bc712
   0
   ef4a59a3-5bda-4ef3-bd5c-b14601d23a94
   268435456
   dacc9bf5b8f16a4b1e1fde78ff2f8e1d
#58 Posted : Wednesday, January 3, 2018 10:33:04 AM(UTC)
Can you please provide step by step instructions to cause the error?
dark_ata
#59 Posted : Wednesday, January 3, 2018 10:54:33 AM(UTC)
dark_ata
#60 Posted : Wednesday, January 3, 2018 11:12:23 AM(UTC)
Can you try with a new blank preset, there must be something mixed up in that preset
as I have followed your steps exactly and vMix will always prevent assigning a MultiView overlay that causes a loop.
(as happens in the first step in your video)
In the last step I try to select the video in camera 6 and it won't assign because it would cause a loop, so not sure why that is happening in your preset.
4 Pages<1234>
