Joined: 9/13/2016(UTC) Posts: 118   Location: Ukraine Thanks: 6 times Was thanked: 5 time(s) in 4 post(s)
this is good, but when it will be possible to stream 2 different outputs, for example master and external 2?
Joined: 9/7/2017(UTC) Posts: 6 Location: Raleigh, NC, USA
Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Curt M wrote:Output Streaming quality #1 is locked in H.264 1920x1080 1080p, with no access to the sprocket to change this function. I can set the stream quality for destinations 2 and 3 (or select to use same as #1) fine.
Some of my work has to be done at 720p for two outputs due to bandwidth up at location. I can use 2 & 3 and go to "None" on #1. but then it elminates my ability to use 3 streams if I'd like to, unless I have more bandwidth
I've looked in the big Setting page, and this condition of quality setting does not change, even with changes to display options.
Am I missing something?
Thanks in advance Yes, I had the same issue. I resolved the problem by rebuilding the Stream Profile.
Joined: 1/13/2010(UTC) Posts: 5,317  Location: Gold Coast, Australia Was thanked: 4718 time(s) in 1616 post(s)
If anyone is seeing the Stream #1 quality greyed out can you go to Settings -> About and click Send Support Report and drop us an email at info@vmix.com.au so we can resolve it. Thanks, Martin vMix
Joined: 4/10/2016(UTC) Posts: 29  Location: Florida, USA Was thanked: 3 time(s) in 3 post(s)
Ezekiel3vs18 wrote:Curt M wrote:Output Streaming quality #1 is locked in H.264 1920x1080 1080p, with no access to the sprocket to change this function. I can set the stream quality for destinations 2 and 3 (or select to use same as #1) fine.
Thanks in advance Yes, I had the same issue. I resolved the problem by rebuilding the Stream Profile. Ok. I'll bite: How do you do that? I'm sure it's not as simple as just changing to another streaming location. I just tried to shift it to YouTube Live and then back. Both settings still grey. Thanks in advance for the fix specifics!
Thanks in advance Yes, I had the same issue. I resolved the problem by rebuilding the Stream Profile. I pulled up the stream page, left it on #1, then did "delete." Once I did that, the sprocket lit up and the line to the left wasn't greyed anymore, and then you can get to the frame to configure your settings. Easy enough to work around! Thanks for the general directions that got me there!
I've been informed the lower cost options of NewBlue Titler Live will be available to purchase in a couple of weeks time starting from around $450 USD. Broadcast was released first.
 5 users thanked admin for this useful post.
I have some NDI sources with 8 audio channels but I need only the 2 first ones. So, I use the newly added Channel Matrix under Input > General > Audio Settings to select the first channel as L and the second as R for all bus. But when saving the configuration, closing vMix and reopening the saved configuration, these parameters are forgotten and the Channel Matrix went back to its defaults. Is there a way to include this in the saved configuration?
Thanks for reporting this, there appears to be a bug where 6 and 8 channels are reset to default. This will be fixed in the next update.
After updating after recording more than 2 hours gives an error
The name of the failed application: vMix64.exe, version: 20.0.0.30, time stamp: 0x59cc70e1 The name of the failed module: mscorwks.dll, version: 2.0.50727.8745, time stamp: 0x573d296c Exception code: 0xc0000005
Hi, I still have the same problems in this version of vMix: Quote:Event filter with query "SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA" Win32_Processor "AND TargetInstance.LoadPercentage> 99" could not be reactivated in namespace "//./root/CIMV2" because of error 0x80041003. Events can not be delivered through this filter until the problem is corrected.
.NET Runtime version 2.0.50727.8762 - Critical Runtime Error (000007FEF340104E) (80131506)
Name of application causing the error: VMIX64.EXE, version: 20.0.0.30, timestamp: 0x59cc70e1 Name of module causing the error: mscorwks.dll, version: 2.0.50727.8762, timestamp: 0x58e462f0
Exception code: 0xc0000005 Error offset: 0x000000000055bd8b Process ID causing the error: 0x%9 Runtime error: 0x%10 Application path causing error: %11 Path of error causing module: %12 Report ID: %13
- System
- Provider
[Name] Application Error - EventID 1000
[Qualifiers] 0 Level 2 Task 100 Keywords 0x80000000000000 - TimeCreated
[SystemTime] 2017-10-15T13: 33: 11.000000000Z EventRecordID 73372 Channel Application Computer AMD-EMISJA Security
- EventData
VMIX64.EXE 20.0.0.30 59cc70e1 mscorwks.dll 2.0.50727.8762 58e462f0 c0000005 000000000055bd8b I translate it in Google Translator, because I have Windows7 Pro in Polish language version. These problems every three hours completely shut down vMix and stop my transmission. Please for help about it and very sorry for my English. Regards for All, adam
Hi, Please drop us an email at info@vmix.com.au regarding the error after recording so we can investigate further. We have been recording for many hours without issue, so it may be particular to the recording format used, or maybe a bug in a driver or codec. Regards, Martin vMix
Thanks: 11 times Was thanked: 3 time(s) in 1 post(s)
Hello! First I'm sorry for my bad English. When display 2 is on and function ''On top'' is on, all dropdown menus is not there that supposed to be. Configuration: 4 Monitors (2 TV, 2 Monitors) Videocard: Nvidia Geforce GTX 980 Gygabute G1 Gaming 4GB or EVGA GeForce GTX 970 SC GAMING ACX 2.0 4GB Procesor: Intel i7 5820K 3.30 GHz overclocked to 4.2 Ghz with liquid cooling RAM: Hyper X Savage DDR 4 2x8GB Power Suplay: FSP 650W Windows 10 Best regards, Gplay TV File Attachment(s):  Screenshot 1.png (2,723kb) downloaded 28 time(s). Screenshot 2.png (3,069kb) downloaded 19 time(s). Screenshot 3.png (3,146kb) downloaded 20 time(s). Screenshot 5.png (3,138kb) downloaded 12 time(s).prass attached the following image(s):  Screenshot 4.png (2,383kb) downloaded 6 time(s).You cannot view/download attachments. Try to login or register.
Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
It says "* Basic support for photos added to List input" in the changelog, so I put some photos (.jpg and .png) together with some videos in a list, but it skipped the photos very fast. I think it also worked like this before the update.
Is there going to be a way to set the time a photo is shown? And maybe even add transitions between the items? Actually it would be great to have the option to add basically any input to the list, even XAML files to show some social media posts or stats within the list.
Regards, Patrick
Update: I just updated to version 20.0.0.42 and it seems that the skip through only occurs on PNG files. JPGs are shown for about 10 seconds.
Hi!
maybe a slight problem with 20.0.0.44 and VST3? Maybe you can reproduce the same error?
When closing vMix with several plugins windows opened, vMix display an error message and fails to stop nicely. When all plugin windows are closed BEFORE closing vMix, it's fine.
Not a big deal but I got this 3 times in 2 days.
Bien à vous, Guillaume
I'm not seeing this with some quick tests, but I guess it depends on the type of plugins being loaded. Maybe a certain combination of plugin brands is more prone to the error.
Martin vMix
Thanks: 11 times Was thanked: 18 time(s) in 13 post(s)
Yesterday the vmix crash while we uses it as mixer for TV, and also see some stranger thing in the proyect, in one of the dual screen was impossible put the source 6, the background was put in loop, disable the auto start restart or pause, and stoped the video, and when change some source one video that uses for try start playing alone... Code:
- System
- Provider
[ Name] Windows Error Reporting
- EventID 1001
[ Qualifiers] 0
Level 4
Task 0
- TimeCreated
[ SystemTime] 2018-01-01T00:22:55.940421300Z
EventRecordID 10153
Channel Application
Computer DESKTOP-U5JOS5D
Security
- EventData
0
CLR20r3
No disponible
0
vmix64.exe
20.0.0.46
5a293c11
mscorlib
2.0.0.0
59a72025
1a4b
0
System.StackOverflowException
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\AppCrash_vmix64.exe_8619b78a18a9e5e1478332cb72415cb77d3fbb4d_00000000_077d4569
0
1fa468d5-d666-4dc5-97ff-3954ee712cf8
6
CRITICAL BUG with the multiview of a source (1) disabled and with that source (1) loaded in a multiview (2) if by mistake you put in the source (1) with the multiview disabled the source (2) closes. I know it's a loop, but it can happen. i think that if the multiview in one source is disable this not could charge/play anything this was all the stranger thing that i see in the post. but the crash report not is the same when crash for the loop of sources the report is Code:- System
- Provider
- EventID 1001
[ Qualifiers] 0
Level 4
Task 0
- TimeCreated
[ SystemTime] 2018-01-02T13:12:02.928617000Z
EventRecordID 10297
Channel Application
Security
- EventData
2170698156674616861
4
APPCRASH
No disponible
0
vMix64.exe
20.0.0.46
5a293c11
KERNELBASE.dll
6.2.16299.15
4736733c
e053534f
0000000000013fb8
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERB947.tmp.mdmp \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERC109.tmp.WERInternalMetadata.xml \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERC116.tmp.csv \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERC127.tmp.txt
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_vMix64.exe_94ce7f5f0d848444ffd224738bac415f7c78218_00000000_6f0bc712
0
ef4a59a3-5bda-4ef3-bd5c-b14601d23a94
268435456
dacc9bf5b8f16a4b1e1fde78ff2f8e1d
Can you please provide step by step instructions to cause the error?
Can you try with a new blank preset, there must be something mixed up in that preset as I have followed your steps exactly and vMix will always prevent assigning a MultiView overlay that causes a loop. (as happens in the first step in your video)
In the last step I try to select the video in camera 6 and it won't assign because it would cause a loop, so not sure why that is happening in your preset.
